February 5, 2004, 06:29 |
How can I link a ne
How can I link a new solver to FoamX case manager, for example dieselEngineFoam or if I edit a new solver. For now, when I create a new case, the solver dieselEngineFoam is absent. Thank Torn |
February 5, 2004, 08:03 |
The configuration files for F
The configuration files for FoamX are in the $FOAMX_SYSTEM_CONFIG directory. They can be modified or added to. (In fact you can put personal changes in a directory $FOAMX_USER_CONFIG to avoid losing them during an upgrade of FOAM; $FOAMX_USER_CONFIG should have the same directory hierarchy as $FOAMX_SYSTEM_CONFIG)
dieselEngineFoam is the only solver that does not currently have a tutorial case or FoamX configuration associated with it (because it is very new). We will endeavour to supply a case and configuration in the next release of FOAM. |
October 28, 2005, 05:27 |
Where can I find the $FOA
Boris Deegen
Where can I find the $FOAM_SYSTEM_CONFIG directory? I have copy the FoamX file from the engineFoamsolver and now the dieselEngineFoam solver is listed in the FoamXCaseBrowser. It is able to open a case under dieselEngineFoam but how can I ceate the directories with spraymodel- or injector settings? I need help. Thank you Boris |
October 28, 2005, 05:32 |
Sorry,
I would say dictionari
Boris Deegen
Sorry,
I would say dictionaries (like turbulencProperties) and not directories. |
November 27, 2006, 06:23 |
Hej,
I have problems with a
Hej,
I have problems with adding a user application class. When typing "echo $FOAM_USER_CONFIG" I just receive a empty line as answer....? Could anyone help me with this problem? thank you, Rita |
February 8, 2009, 18:50 |
Dear All
i successed to
Nugroho Adi
Rep Power: 17 |
Dear All
i successed to make a new solver by using twoPhaseEulerFoam base solver. i called it as my_twoPhaseEulerFoam. i put Temperature on it and i successed use it manually to simulate tutorial cases with Temperature on bed, bed2 and bubblecolumn without error message. and i also try to put this new solver in FoamX. and success, it is shown in the solvers list. but the problem is: the Temperature ''feature'' that i put on the new solver doesnt show on the new case window that i made on FoamX. so i dont find Temperature column on the Fields list , for filling the Temperature boundary condition value (also in the Patch option) is there anyone knows how to solve my problem? please help me. Regards Nugroho Adi |
segregated solver vrs coupled solver | sm | FLUENT | 0 | November 6, 2007 01:24 |
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver | dandes | OpenFOAM Pre-Processing | 0 | March 22, 2006 21:06 |
AGM-SOLVER | MANOJ | FLUENT | 5 | August 1, 2005 04:49 |
solver | fuf | FLUENT | 0 | June 19, 2003 13:54 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 08:30 |
