May 15, 2009, 09:04 |
Pressure inlet condition
sivakumar
Rep Power: 16 |
hello all user,
I am trying to set the pressure BC at inlet, i have given pressureInletOutVelocity. but its giving error Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0231447, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0236254, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0239755, No Iterations 2 gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type pressureInletoutletVelocity) on patch inlet of field p in file "/home_local/projects/CT-110_BSH/SimpleCFD_version1/0/p" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692. FOAM exiting I tried pressuerInletVelocity also its giving the same error i have attached my 0/p also please have look and help me do fix the problem. with regards, sivakumar |
May 18, 2009, 02:16 |
#2 | |
Mark Olesen
Rep Power: 40 |
May 18, 2009, 05:00 |
sivakumar
Rep Power: 16 |
hi,
thank you for u r message. with friendly, sivakumar |
October 28, 2010, 23:57 |
hoaiphuong
Rep Power: 15 |
Hi, everyone !
I have a problem about inlet condition I set inlet pressure as " Total pressure model with relative pressure = 101325 Pa " And in CFX - post, I chose Total pressure to indicate the result but it didn't exactly indicate the pressure I set in CFX - Pre Please give me an advice! Thank you very much in advance! |
Question about pressure inlet boundary condition. | Alina | FLUENT | 1 | November 30, 2007 07:39 |
Pressure Inlet yields wrong velocities | Ben | FLUENT | 0 | November 21, 2004 01:47 |
pulsating inlet boundary condition | Jason | CFX | 1 | July 29, 2004 11:47 |
inlet and outlet boundary condition of pump | Thammasak | CFX | 0 | February 9, 2004 13:02 |
Pressure inlet definitions | Christian | FLUENT | 0 | April 15, 2003 07:24 |
