DamBreakFine Problem
Old   May 12, 2006, 10:03
Default Dear OpenFOAM users, I am new
Kenneth Tease
kendo is on a distinguished road
I am new to OpenFOAM and am learning more about the package. I have a Dual processor Dell PC and have been experimenting with running the damBreakFine2 tutorial case.
I am an having problems with updating the gamma distribution on the new fine mesh. Note initial setup as single processor job because problem seens to be with setFields?
Any suggestion would be helpful?
Regards,
Ken
1) Cloned the damBreak(not running any procedures on it like blockmesh and stuff) case to damBreakFine2
2) Changed the blockMeshDict file according to the tutorial. did not change any other files.
3) Ran blockMesh on damBreakFine2. New finer mesh was formed OK for it was visible in paraview, but got the following errors:
FOAM Warning:
From function polyMesh::polyMesh(… construct from shapes…)
in file meshes/polyMesh/createPolyMesh.C at line 467
Found 10 undefined faces in mesh; adding to default patch.
The rest processed OK and new mesh was formed.
4) Ran setFields on damBreakFine2
Got the following error:
FOAM FATAL IO ERROR : size 2268 is not equal to the given value of 7700
File: /home/………../damBreakFine2/0/gamma from line 25 to line 2323.
From function Field<type>::Field(const word& keyword, const dictionary& dict, const label s) in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.2/src/OPENFOAM/lnInclude/Field.C at line 225.
kendo is offline   Reply With Quote
Old   May 15, 2006, 14:29
Default Start off from a 'uniform' gam
Mattijs Janssens
Start off from a 'uniform' gamma. (can be copied from the original tutorial)
Or 'mapFields' from your existing solution.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
DamBreakFine in a 2PC cluster problem parallelauvi OpenFOAM Running, Solving & CFD 1 April 12, 2006 12:17
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
