Impose a square function on fvOptions
Old   September 21, 2022, 03:27
Default Impose a square function on fvOptions
Giulia
letoppina is on a distinguished road
I am using OpenFOAM version 6 and chtmuliregionfoam. I am using the following code to impose a sinusoidal heat source on my solid region throughout my fvOptions file:
energySource
        type            scalarCodedSource;
        active          yes;
        timeStart       0;
        duration        1e6;
        name            sourceTime;
    selectionMode   all;
    scalarCodedSourceCoeffs
        selectionMode   all;
                volumeMode      specific;
        fields          (h);
            codeInclude
            codeCorrect
                Pout<< "**codeCorrect**" << endl;
            codeAddSup
                    const Time& time = mesh().time();
                    const scalarField& V = mesh_.V();
                    const vectorField& C = mesh_.C();
                    scalarField& heSource = eqn.source();
            heSource += 2.729e6*sin(2*3.14*0.1*time.value())*V;
                Pout << "***codeAddSup***" << endl;
            codeSetValue
                Pout<< "**codeSetValue**" << endl;
            // Dummy entry. Make dependent on above to trigger recompilation
               code
                    $codeInclude
                    $codeCorrect
                    $codeAddSup
                    $codeSetValue
Is it possible to impose a square function instead of a sinusoidal one? Or impose a table of values?
Thank you in advance!!
letoppina is offline   Reply With Quote
chtmultiregionfoam, fvoptions, heat source, sinusoidal, square wave
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
