Set fields for an internal patch (surface)
Old   July 29, 2011, 09:53
Default Set fields for an internal patch (surface)
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi Foamers
I need to define a parameter (e.g.some traction or temperature in a thermal-stress analysis) for a surface inside the geometry (not at boundary).
My idea is that I can use setFields for the internal surface. One of the valid topoSetSource types that suggests such possibility is patchToFace. So is it possible to define an internal patch and refer to it in setFieldsDict? Else, how can I solve my problem?
Thanks a lot.
Best regards,
Hisham
Hisham is offline   Reply With Quote
Old   July 30, 2011, 07:02
Hisham's Avatar
Hisham Elsafti
I have tried to modify the plateHole example of the solidDisplacementFoam solver. I have introduced internal patches via new (6) vertices, modified patches and edges, added (4) boundaries and a merge of two:
vertices
(0.5 0 0)//0
(1 0 0)
(2 0 0)
(2 0.707107 0)//3
(0.707107 0.707107 0)//4
(0.353553 0.353553 0)//5
(2 2 0)
(0.707107 2 0)
(0 2 0)
(0 1 0)
(0 0.5 0)//10
(0.5 0 0.5)//+11
(1 0 0.5)
(2 0 0.5)
(2 0.707107 0.5)//14
(0.707107 0.707107 0.5)//15
(0.353553 0.353553 0.5)
(2 2 0.5)
(0.707107 2 0.5)
(0 2 0.5)
(0 1 0.5)//20
(0 0.5 0.5)
(2 0.707107 0)//22 -- 3
(0.707107 0.707107 0)//23 -- 4
(2 0.707107 0.5)//24 -- 14
(0.707107 0.707107 0.5)//25 -- 15
(0.353553 0.353553 0)//26 -- 5
(0.353553 0.353553 0.5) //27 -- 16
blocks
hex (5 4 9 10 16 15 20 21) (10 10 1) simpleGrading (1 1 1)//0
hex (0 1 23 26 11 12 25 27) (10 10 1) simpleGrading (1 1 1)//1
hex (1 2 22 23 12 13 24 25) (20 10 1) simpleGrading (1 1 1)//2
hex (4 3 6 7 15 14 17 18) (20 20 1) simpleGrading (1 1 1)//3
hex (9 4 7 8 20 15 18 19) (10 20 1) simpleGrading (1 1 1)//4
edges
arc 0 26 (0.469846 0.17101 0)
arc 5 10 (0.17101 0.469846 0)
arc 1 23 (0.939693 0.34202 0)
arc 4 9 (0.34202 0.939693 0)
arc 11 27 (0.469846 0.17101 0.5)
arc 16 21 (0.17101 0.469846 0.5)
arc 12 25 (0.939693 0.34202 0.5)
arc 15 20 (0.34202 0.939693 0.5)
boundary
left
type symmetryPlane;
faces
(8 9 20 19)
(9 10 21 20)
right
type patch;
faces
(2 22 24 13)
(3 6 17 14)
down
type symmetryPlane;
faces
(0 1 12 11)
(1 2 13 12)
up
type patch;
faces
(7 8 19 18)
(6 7 18 17)
hole
type patch;
faces
(5 10 21 16)
(0 26 27 11)
frontAndBack
type empty;
faces
(10 9 4 5)
(26 23 1 0)
(1 23 22 2)
(4 7 6 3)
(4 9 8 7)
(21 16 15 20)
(27 11 12 25)
(12 13 24 25)
(15 14 17 18)
(15 18 19 20)
myInternal1
type patch;
faces
(3 4 15 14)
myInternal2
type patch;
faces
(23 22 24 25)
myInternal3
type patch;
faces
(4 5 16 15)
myInternal4
type patch;
faces
(26 23 25 27)
mergePatchPairs
(myInternal3 myInternal4)
Doing so I was able to introduce temperature (T) to internal patches (boundaries) myInternal1 & 2 as:
myInternal1
//type zeroGradient;
type fixedValue;
value uniform 1000;
myInternal2
type fixedValue;
value uniform 1000;
and displacement D as:
myInternal1
type tractionDisplacement;
traction uniform ( 0 0 0 );
pressure uniform 0;
value uniform (0 0 0);
myInternal2
pressure uniform 0;
Nevertheless, the results indicate discontinuity in displacements at the nonmerged patches. How can I overcome this and still be able to introduce (T), (D) or traction at the same line?
Links to images:
https://picasaweb.google.com/1169016...96155045483218
https://picasaweb.google.com/1169016...96095904159202
https://picasaweb.google.com/1169016...96152225853202
internal patch, patchtoface, setfields
[ICEM] Patch dependent surface mesh problem! hadikhayyamian ANSYS Meshing & Geometry 14 January 27, 2018 08:47
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
mapFields : internal edges Gearb0x OpenFOAM Running, Solving & CFD 3 April 19, 2010 09:02
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
