codedFixedValue boundary condition
Like Tree7Likes
Old   March 20, 2012, 12:41
Goutam Saha
Goutam is on a distinguished road
[CODE]
inlet
type codedFixedValue;
value $internalField;
redirectType ramp;
code
scalar U_0 = 0.003,
scalar r = 0.025;
fixedValueFvPatchField<vector> myPatch(
this->Cf().size());
forAll(this->Cf(), i)
myPatch[i] = vector( 2*U_0*(1 - Foam:ow(this->Cf()[i].x(), 2) / r / r )),0,0);
(*this)== myPatch;
I got the following error:
Using dynamicCode for patch inlet on field U at line 25 in "/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet"
Creating new library in "dynamicCode/ramp/platforms/linux64GccDPOpt/lib/libramp_33868748d21fc6c5f633c2f3604861e34d0d7dc7.s o"
Invoking "wmake -s libso /home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/dynamicCode/ramp"
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file fixedValueFvPatchFieldTemplate.C
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet: In member function ‘virtual void Foam::rampFixedValueFvPatchVectorField::updateCoef fs()’:
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet:32: error: ‘class Foam::rampFixedValueFvPatchVectorField’ has no member named ‘Cf’
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet:32: error: expected primary-expression before ‘)’ token
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet:32: error: expected ‘;’ before ‘)’ token
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet:33: error: ‘class Foam::rampFixedValueFvPatchVectorField’ has no member named ‘Cf’
/home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet:33: error: expected ‘;’ before ‘)’ token
make: *** [Make/linux64GccDPOpt/fixedValueFvPatchFieldTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/ramp/platforms/linux64GccDPOpt/lib/libramp_33868748d21fc6c5f633c2f3604861e34d0d7dc7.s o"
file: /home/thermo/gsaha/OpenFOAM/gsaha-2.1.0/run/tutorials/incompressible/simpleFoam/parabolicflow/0/U::boundaryField::inlet from line 25 to line 30.
From function codedBase::createLibrary(..)
in file db/dynamicLibrary/codedBase/codedBase.C at line 202.
FOAM exiting
Goutam is offline   Reply With Quote
Old   March 20, 2012, 17:40
Wouter van der Meer
wouter is on a distinguished road
hello,
there is a , instead of ;
scalar U_0 = 0.003,
But you probably found that already.
all the best,
Wouter
wouter is offline   Reply With Quote
Old   March 21, 2012, 04:28
Default Error code: has no member named ‘Cf’
  #23
Goutam Saha
[CODE]
inlet
redirectType ramp;
code
scalar U_0 = 0.003;
scalar r = 0.025;
this->Cf().size());
{ myPatch[i] = vector( 2*U_0*(1 - Foamow(this->Cf()[i].x(), 2) / pow(r,2)),0,0); }
(*this)== myPatch;
Thanks All
Old   March 22, 2012, 02:15
November is on a distinguished road
Greetings guys...
I want to apply a codedFixedValue to a 0/p for the inlet of an oscillatory flow... according to NS equation that p value should have something like p=-2*pi*f*U_m*cos(2*pi*f*t)x, so at left boundary x=-20 therefore this equation becomes p=-2*pi*f*U_m*cos(2*pi*f*t)*(-20).
I want to realize that p BC by codedFixedValue as following:
inlet
value uniform 0;
redirectType rampedFixedValue;
code
operator==40*3.141*1*cos(3.141*0.5*this->db().time().value());
However I keep getting the following error msg:
Loading a shared library using case-supplied code is not enabled by default
because of security issues. If you trust the code you can enable this
facility be adding to the InfoSwitches setting in the system controlDict:
allowSystemOperations 1
The system controlDict is either
~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict
or
$WM_PROJECT_DIR/etc/controlDict
file: /home/kyang/OpenFOAM/OpenFOAM-2.1.0/icoFoam-t/3DCylinder/0/p::boundaryField::inlet from line 35 to line 39.
From function codedBase::updateLibrary()
in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 81.
FOAM exiting
I wonder if in order to use the codedFixedValue, one has to do something like in the msg: "adding to the InfoSwitches setting in the system controlDict: allowSystemOperations 1"?? But I'm not sure how exactly to do that?? What is the InfoSwitches setting in controlDict?? I copied "allowSystemOperations 1" to controlDict and it didnt work....
November is offline   Reply With Quote
Old   March 22, 2012, 15:45
Retired Super Moderator
Bruno Santos
Greetings November,
I've written about this some time ago... read this section: 2.1 Additional tuning
Best regards,
Bruno
Old   March 23, 2012, 00:16
Originally Posted by wyldckat View Post
Greetings November,
I written about this some time ago... read this section: 2.1 Additional tuning
Best regards,
Bruno
Thanks a lot Bruno!!! I can apply the coded BC now however...
I am trying to simulate a very easy problem - oscillatory flow around a circular cylinder (3D), however I got stuck for the inlet and outlet boundary conditions here... and have been searching the web for solutions but without luck..
so, I want a inlet velocity at u_x=U_m*sin(2*pi*f*t), U_m=1m/s, u_y=0, u_z=0. Therefore I have specified for the inlet and outlet BC in 0/u as followings:
code:
inlet
type oscillatingFixedValue;
refValue uniform (0 0 0);
//offset (0 -1 0);
amplitude constant 1;
frequency constant 0.5;
value uniform (0 0 0);//dummy OF
outlet
type zeroGradient;
and for the 0/p, I first tried to put for inlet the "fixedValue=0" but the results are not good. So I guessed according to NS, dp/dx=-du/dt at inlet, therefore dp/dx can bu calculated according to u_x, and do an intergral one gets the p=-2*pi*f*U_m*cos(2*pi*f*t)*x....So I decided to use the codedFixedValue for that p:
inlet
value uniform 0;
redirectType rampedFixedValue; // what does this mean??
code
(*this)==40*3.141*1*cos(3.141*0.5*this->db().time().value()); // 40 because x=-20 at inlet
outlet
type fixedValue;
value 0;
But the results gets non-convergent after sometime...
Specifying the BC of inlet and outlet for an oscillatory flow around a circular cylinder... It looks easy however I couldnt find an example as how people did it... I am really confused now...Could you give me some hints??? Thanks in advance!!
Old   April 11, 2012, 11:18
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Originally Posted by Goutam View Post
[CODE]
Thanks All
Hi Goutam,
Had you any luck applying your BC????
Anyways, this works with me:
this->patch().Cf()
Best regards,
Hisham
Hisham is offline   Reply With Quote
Old   April 12, 2012, 05:22
Goutam Saha
I wrote the following code and now its working:
inlet
redirectType ramp;
code
scalar U_0=0.001934;
scalar r=0.02595;
fixedValueFvPatchVectorField myPatch(*this);
forAll(this->patch().Cf(),i)
myPatch[i]=vector(2*U_0*(1-Foam:ow(this->patch().Cf()[i].x(),2)/r/r),0,0);
operator==(myPatch);
Old   September 6, 2012, 08:12
Ali Abbasi
aabbasi59 is on a distinguished road
Send a message via Skype™ to aabbasi59
Hi Friends,
I want to use codedFixedValue boundaryfield for boundary condition in Inlet for U. If I used constant value for equation it works but when I want to put values from another file it doesn't work. How can I force this patch-type for reading a constant from another file(e.g., include/initials)??
My code is:
inlet
redirectType velocity_inlet;
code
scalar Ustar=$Ustar;;
scalar k=0.42;
scalar z0=2.25e-4;
myPatch[i]=vector(Ustar/k*(Foam::log((this->patch().Cf()[i].y()+z0)/z0)),0,0);
and I get the error below:
‘Ustar’ was not declared in this scope
Thanks a lot in advance.
Ali
aabbasi59 is offline   Reply With Quote
Old   September 14, 2012, 09:28
ae-lab VUB
aevub is on a distinguished road
Hi
I am trying to make a ramped BC as mentioned above (Tomasso Lucchini's rampedFixedValue BC).
It compiles, but when using it in the cavitycase I get this error:
Foam::error:rintStack(Foam::Ostream&) in "/home/mvdtempe/OpenFOAM/OpenFOAM-2.1.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
Foam::sigSegv::sigHandler(int) in "/home/mvdtempe/OpenFOAM/OpenFOAM-2.1.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
Uninterpreted:
void Foam::dot<Foam::Vector<double>, Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::inne rProduct<Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/mvdtempe/OpenFOAM/OpenFOAM-2.1.x/platforms/linuxGccDPOpt/bin/icoFoam"
at icoFoam.C:0
__libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Segmentation fault (core dumped)
I use 2.1.x
aevub is offline   Reply With Quote
Old   December 12, 2014, 05:43
hello
hesong is on a distinguished road
I am trying to define a boundary condition, T(Temperature) will change with a Z(coordinates). But I don’t know ,which boundary should I user ,movingwall or front,etc;
I NEED HELP
myPatch
value uniform 0;
redirectType myFixedValue; // name of generated BC
code
forAll(*this, i)
scalar z = patch().Cf()[i][2];
if (z > 0 && z < 32)
(*this)[i] = 0.0075 * z -1.58;
else if (...)
else
codeInclude
#include "fvCFD.H"
codeOptions
-I$(LIB_SRC)/finiteVolume/lnInclude
hesong is offline   Reply With Quote
Old   December 12, 2014, 05:49
Ali Abbasi
@hesong
Why don't you use groovyBC!? For your B.C the groovyBC could be the best choice.
Old   December 12, 2014, 06:00
hello
Originally Posted by aabbasi59 View Post
@hesong
thank you !
could you provide some detailed information
I just learn this software for several months.
Old   December 12, 2014, 06:08
Ali Abbasi
Using groovyBC for complex BCs is straightforward. You can search it in the forum and find a lot of resources on working with groovyBC and swak4FOAM:
https://openfoamwiki.net/index.php/Contrib/groovyBC
https://openfoamwiki.net/index.php/Contrib/swak4Foam
http://www.cfd-online.com/Forums/tags/groovybc.html
http://www.cfd-online.com/Forums/ope...locity-bc.html
I hope you can find your solution.
Old   April 23, 2015, 11:50
Mehtab
mehtab is on a distinguished road
Hi Foamers,
I want to implement a boundary condition at inlet.
𝑇_𝑠=𝑇_0+1/𝐶_𝑝 [𝑄_𝑓/(𝑚*̇ " )*̇ −𝐻_𝑣𝑎𝑝 ]
In this equation Q_f and 𝑚*̇ " need to be taken from inlet at previous time step.
Is it possible to do it using grovyBC or codedFixedValue in Openfoam? Which one be easier to implement?
Thanks in advance.....
mehtab is offline   Reply With Quote
Old   April 14, 2016, 02:51
usv001 is on a distinguished road
Hello everybody,
I am experimenting with #codestream and codedFixedValue boundary conditions. I was able to implement #codeStream successfully for the internalField. But I am having a lot of trouble with codedFixedValue. I can't even get the example code given in the documentation to work. The code is compiling without mistakes but when I view it in Paraview it is applying the value (uniform 0) that is specified for 'value'. Any idea why codedFixedValue does not work for me?
By the way, I am using OF 2.1.1. Thank you very much.
usv001 is offline   Reply With Quote
Old   April 14, 2016, 06:08
I want to try something advanced but I am not sure of OF syntax and such.I just want to clarify if this code is supposed to work. It is just setting some fixed value.
NOZZLE_INLET
	value 		uniform 400000;
	redirectType	random;
    code
        operator == (200000);
    codeInclude
        #include "fvCFD.H"
    codeOptions
I know this doesn't require codedFixedValue but just wondering if it should work. Like I said in my previous post, the codedFixedValue does not show any errors when I run Paraview but it shows 400000 for the patch instead of 200000.
Once again, thanks everyone.
Old   April 15, 2016, 18:10
Bruno Santos
Quick answer: Given how you coded it, the value is only updated in the first time step of the solver or at least when you run decomposePar.
Old   April 16, 2016, 08:53
Hi Bruno,
Thank you very much for replying me. Really appreciate you taking your time to help others.
I used decomposePar and then reconstructPar to see if the changes take effect but there seems to be no change at all. The #code section is still being ignored.
Old   April 16, 2016, 16:27
Bruno Santos
Hi usv001,
Something very strange is going on here... at least in my machine. I would have to rebuild OpenFOAM 2.1.1 from source code to fix the problem on my side and I don't feel like it right now.
There are two things I need to you test/check:
  1. Run the tutorial case "incompressible/simpleFoam/pipeCyclic". To run it:
    ./Allrun
    Then inspect the contents of the file "log.simpleFoam". I ask this because this tutorial should work as intended.
  2. The code you're using has a flaw... this:
    should be at least like this:
    operator==(200000);
Because I suspect that the boundary condition isn't even being built in your case, because you should see a pretty glaring error message when trying to use decomposePar.
In addition to this, which Linux Distribution and version are you using?
Best regards,
Bruno
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
