Geometry and mesh generation in OpenFoam
Old   October 25, 2011, 11:29
Default Geometry and mesh generation in OpenFoam
pokeng's Avatar
José Manuel Juárez
pokeng is on a distinguished road
Send a message via MSN to pokeng Send a message via Yahoo to pokeng
Hello!
In new in the openfoam world. So far, i just solved the tutorials of the user guide. My main contact with the CFD world is with ansys, Fluent and CFX. When using ansys, i used to generate the geometry in CAD software (PRO-E or Solid Works) and then import this from ansys to mesh it.
What is the best path in openfoam to generate and to mesh complex geometries with open source code? I have done some research and found that salome is good tool to do the pre-processing work, but, does it work with openfoam? Or maybe is better to work with comercial cad software and then export to a mesh software? I am trying to stablish a simulation enviroment based completely on open source code. I would like to read your sugestions about this subject. Thanks!
pokeng is offline   Reply With Quote
Old   October 28, 2011, 21:40
Default Salome work
Wesley T.
Wesley is on a distinguished road
Yes, Salome works well. The CAELinux distribution at least used to have tutorials showing how to work that program with OpenFOAM.
The only issue I have had with Salome is as a get into generating more complex geometries, the program sometimes creates "non-valid" shapes - shapes it can't use to cut other shapes or can't mesh. My personal problem is trying to create a helical screw (take a cylinder and cut out a helix with a circular cross-section). I have not been able to solve that geometry.
Wes
Wesley is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
