February 8, 2012, 03:57 |
inflated quadratic element mesh
Hello
I've been trying to change the parameters of simpleGrading in the mesh file so that I get smaller quadratic orthogonal elements near the edges. However, I seem to only be able to make them refined on one side. I just have a square cross-section that I would like to refine at the edges. Thank you very much Kind Regards, F |
February 8, 2012, 11:32 |
Apologies for the noob question, but where do I put the folder that I just downloaded?
Rgds, F |
February 8, 2012, 11:37 |
Anton Kidess
Rep Power: 29 |
In principle any where, but I like to put it in OpenFOAM/user-2.0.x/applications/utilities/. After you extracted the files, run the Allwmake script once and then you can use the utility.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
February 11, 2012, 05:00 |
Hi.
I did as you said, and put the blockmeshdg folder in applications/utilities and then ran allwmake from the folder but it told me the command didn't exist. i also tried wmake but it failed. ideas? Kindest regards, F |
February 11, 2012, 07:30 |
Anton Kidess
Rep Power: 29 |
What happened exactly when you ran ./Allwmake? What was the error message if you got any? Were you able to run any other OpenFOAM commands in the same shell?
The executable name is "blockMeshDG" by the way - the capitalization is important.
February 11, 2012, 09:42 |
Ok it compiles now.
What is the required syntax for having inflated meshes at each side of a square? simpleGrading I suppose would not incorporate this effect? Kindest Regards, Francesco |
February 11, 2012, 10:06 |
Anton Kidess
Rep Power: 29 |
Use it just like the standard blockMesh, but use negative coefficients where you want double grading.
February 15, 2012, 02:54 |
Awesome.
That works very nicely. Thank you very much. F |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Negative element volume & folded mesh in cfx 11.0 | siavash ghassemi | CFX | 2 | December 28, 2007 13:17 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
