Extract cells from multiple cell zones
Like Tree1Likes
  • 1 Post By olesen
Old   May 2, 2012, 22:18
Post Extract cells from multiple cell zones
deok-kyu choi
ggoggodak85 is on a distinguished road
is it possible to extract cells from multiple cell zones?
and how can i set the vector value to selected cells?
regards,
ggoggodak85 is offline   Reply With Quote
Old   May 3, 2012, 02:30
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
regards,
To loop through the cells, you'd need something like the following. Note that this will not work "as is", but is just a guide:
        // cellZoneIds with the IDs of your cell zones
        // mesh_ is a reference to the mesh
        forAll(cellZoneIds, zoneI)
            const labelList& cells = mesh_.cellZones()[cellZoneIds[zoneI]];
            forAll(cells, i)
                // do something for cells[i]
olesen is offline   Reply With Quote
Old   May 4, 2012, 05:46
deok-kyu choi
            forAll(cells, i)
Dear olesen,
finally I did by olesen's favor!
But I'd like to do something more.
Following screenshot, it seems to be calculated for every cells.
How can i apply coriolis force for selected cell zone (celltable_2) ?
zone of celltable_2 is circle area in box.
Here is my code, but is just a guide
forAll(mesh.cellZones(),i)
const cellZone& zone = mesh.cellZones()[i];
if (zone.name()=="cellTable_2")
const labelList& cellLabels = mesh.cellZones()[i];
Info << "Found matching zone " << zone.name() << " with " << cellLabels.size() << " cells." << endl;
forAll(cellLabels, i)
// Calculate the coriolis force in selected cells (cellTable_2)
volVectorField Fcoriolis = Omega ^ (mesh.C() - Origin);
Fcoriolis.write();
regards,
Old   May 4, 2012, 06:39
Mark Olesen
Two approaches.
1. if you will only ever have a single zone:
label zoneId = mesh.cellZones().findIndex("cellTable_2");
if (zoneId != -1)
    const labelList& cellIds = mesh.cellZones()[zoneId];
    forAll(cellIds, i)
2. if you want a regex to select one or more zones:
labelList zoneIds = mesh.cellZones().findIndices("cellTable_[1-3]");
forAll(zoneIds, zoneI)
    const labelList& cellIds = mesh.cellZones()[zoneIds[zoneI]];
    forAll(cellIds, i)
As usual, the code example may not be exactly correct.
mm.abdollahzadeh likes this.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
two adjacent cell zones. Thejasvi FLUENT 3 November 26, 2001 08:35
Tracking/Modifying Cell Zones Greg Perkins FLUENT 1 November 6, 2000 23:35
