Access turbulence model in coded functionobjectlibs
Like Tree1Likes
  • 1 Post By eelcovv
Old   July 11, 2012, 11:23
Default Access turbulence model in coded functionobjectlibs
Eelco van Vliet
eelcovv is on a distinguished road
Dear foamers,
I have been using function object libs now for a while to be able to do some extra coding at run time without modifying the solver.
Now I want to create a code snipped which calculates the RMS value of the solution matrix being solved, so you can access the accuracy of the solution.
My code snipped would look like
errorAnalysis
    functionObjectLibs ("libutilityFunctionObjects.so");
    type coded;
    redirectType average;
    outputControl timeStep;
    code
      const volVectorField&      U=mesh().lookupObject<volVectorField>("U");
      const surfaceScalarField& phi=mesh().lookupObject<surfaceScalarField>("phi");
      const volScalarField&      p=mesh().lookupObject<volScalarField>("p");
fvVectorMatrix residualMatrix
                fvm::ddt(U)
            +  fvm::div(phi, U)
            +  turbulence->divDevReff(U)
            +  fvc::grad(p)
        Info << "RMS residualMatrix: " << Foam::sqrt(gSumMag(magSqr(residualMatrix.residual()))) << nl  ;
This piece of code works if I put it in the solver, but in the coded functionobject libs I do not know how to access the turbulence pointer using the lookupObject. Would somebode know how to access the divDevReff in code snipped dynamically linked at the case level ?
Regards
Eelco
eelcovv is offline   Reply With Quote
Old   July 12, 2012, 10:46
Default work-around
Eelco van Vliet
As a work around in order to access the turbulence->divDevReff from the dynamically linked function object I found the following.
errorAnalysis
    type coded;
    code
      const volScalarField&      nuSgs=U.db().lookupObject<volScalarField>("nuSgs");
      const dictionary& transportProperties = U.db().lookupObject<IOdictionary>
         "transportProperties"
      const dimensionedScalar&   nu(transportProperties.lookup("nu"));
              fvm::ddt(U)
            + fvm::div(phi, U)
            - fvm::laplacian(nu+nuSgs, U) - fvc::div((nu+nuSgs)*dev(T(fvc::grad(U))))
            + fvc::grad(p)
It works, but is rather ugly. I prefer to replace the line fvc::div((nu+nuSgs)*dev(T(fvc::grad(U)))) with turbulence-> value. Does anybody has a hint?
liquidspoon likes this.
Old   August 12, 2012, 00:18
ak
newOFuser is on a distinguished road
Hello
Is the 'type coded' option available in OF 1.7.1? I get an error: Unknown function type coded
Is there a way to implement it in OF 1.7.1?
Thanks!
ak
newOFuser is offline   Reply With Quote
Old   March 7, 2013, 06:54
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
The coded functionObjects seem to be only available in OpenFOAM 2.0+
See this release notes:
http://www.cfd-online.com/Forums/ope...unction+object
GerhardHolzinger is offline   Reply With Quote
Old   August 22, 2013, 12:03
Alex
liquidspoon is on a distinguished road
Hi Eelcovv,
Did you ever have any more success trying to access the turbulence data from coded function objects? I was trying to do something similar, and found the obr() function. This returns a reference to the object registry, which lists the turbulence model, and can supposedly return a reference to it. However, I kept getting errors when I tried to get at the turbulence model through the lookupObject function, but kept getting errors (type incompressible::turbulenceModel not found, foundObject method not valid), and wasn't sure how to link in the required libraries.
liquidspoon is offline   Reply With Quote
Old   December 6, 2016, 21:01
Mahdi Hosseinali
anishtain4 is on a distinguished road
Can anyone please advise how to access turbulenceModel in a coded functionObject?
obr() which is mentioned is the same as mesh() but it only has a reference to turbulence dictionary, not the object itself! I need to access epsilon of an LES simulation which cannot be found through lookupObject. I looked into the file and to calculate it directly I still need k which is the subgridscale kinetic energy in an LES simulation.
anishtain4 is offline   Reply With Quote
Old   December 1, 2018, 18:43
Terrence Nguyen
hismother is on a distinguished road
i am having the same problem. anyone has the solution???
thank you.
hismother is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Turbulence model for mixing problem nileshjrane OpenFOAM Running, Solving & CFD 1 September 7, 2010 17:48
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
