Turbulence Model with Elliptic Relaxation
Old   August 7, 2012, 15:50
Post Turbulence Model with Elliptic Relaxation
twray is on a distinguished road
Hello all,
I've been working on implementing a damping function, fmu, defined by an elliptic relaxation equation. This is the first modification I've done that has required defining my own discretized equation so I'm sure there are errors in my implementation. Also I believe my method of setting the initial and boundary conditions could use improvement. Currently my simpleFoam case compiles and runs but the results are incorrect.
fmu must be between 0 and 1 and equal 0 on wall boundaries. To initialize this I added the code below to the constructor.
In /0/fmu I set a value of 0 to my wall patch and 0.5 to the internalField and all other patches.
fmu_
        IOobject
            "fmu",
            runTime_.timeName(),
            mesh_,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh_
Is this the proper method of defining initial conditions? Is adding something like the following in the constructor without defining a /0/fmu file possible or more appropriate?
dimensionedScalar("fmu",dimless,.5)
label patchWall = mesh_.boundaryMesh().findPatchID("wall")
fmu_.boundaryField()[patchWall]=0.0
The fmu equation is
        const volScalarField Lsqr(this->Lsqr(W,S,Cmu,Tt,k_,epsilon_,zeta));
        tmp<fvScalarMatrix> fmuEqu
            Lsqr*fvm::laplacian(fmu_) == scalar(1.0) - fmu_
        fmuEqu().relax();
        solve(fmuEqu);
        label patchWall = U_.mesh().boundaryMesh().findPatchID("wall");
        fmu_.boundaryField()[patchWall]=0.0;
I moved the negative into my Lsqr function. I added definitions for laplacian(fmu), relaxationFactors and solvers in fvSchemes and fvSolution. The last line is to update the boundary condition on the wall.
Does this procedure look correct? Is using the boudaryField()[patchWall]=0.0 the proper way to correct the wall boundary condition?
Thanks in advance for any input,
Tim
twray is offline   Reply With Quote
Old   August 16, 2012, 12:01
Tarak
Tarak is on a distinguished road
Hii,
You can do something like this so that you do not need to create Initial Condition files for the fields you want to get printed out:
LPrint_
IOobject
"LPrint",
mesh_,
mesh_,
dimensionedScalar("LPrint", dimensionSet(0, 1, 0, 0, 0, 0, 0), 0.0),
zeroGradientFvPatchScalarField::typeName
Tarak is offline   Reply With Quote
Old   August 16, 2012, 15:46
Thanks for the input.
Also, as an update, I use the following to solve the elliptic equation. It seems to be working, but I'm still testing.
            - fvm::laplacian(fmu_) == - fvm::Sp(1.0/Lsqr,fmu_) + 1.0/Lsqr
        fmuEqu().relax();
        solve(fmuEqu);
elliptic, relaxation
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
