How to compile?
Old   September 18, 2012, 08:57
Default How to compile?
Alexander A
A.A. is on a distinguished road
I am absolute beginner in OF and I need to know how to compile if I want to make changes to the oscillatinRotatingMotion:C and .H files.
Could somebody explain the steps to do like for dummies?
Best,
Alex
A.A. is offline   Reply With Quote
Old   September 18, 2012, 15:13
Retired Super Moderator
Bruno Santos
Greetings Alex,
To learn how to create a modified solver: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
The idea is nearly identical when it comes to creating a custom library. The detail is that with libraries, you only have to copy-paste-change what you really want.
I've helped other people with similar situations, where the most recent is this one: http://www.cfd-online.com/Forums/ope...tml#post380430 post #5
Best regards,
Bruno
Old   September 19, 2012, 02:54
Elvis
elvis will become famous soon enough
Dear Alexander,
if you do not already know them
http://www.personal.psu.edu/dab143/OFW6/training.htm =>New Developer Sessions
http://sourceforge.net/projects/open...OAM_Workshops/
http://sourceforge.net/projects/open...tadt/Training/
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/ change year 2007..2012 to see different material
http://www.tfd.chalmers.se/~hani/kur.../debugging.pdf
elvis is offline   Reply With Quote
Old   September 19, 2012, 04:54
Default Hi
Alexander A
I followed the steps in the links you posted.
But if I write this in the terminal $FOAM_USER_APPBIN it says no such file or directory.
As I couldn't find the location above I placed my folder called newApp in $WM_PROJECT_USER_DIR. I hope thats also ok.
I have attached the newApp folder. There I created the Make/files and Make/options
and the code for myoscillatingRotatingMotion. In the code I changed all class names to myoscillatingRotaingMotion.
Then I wrote wmake and also tried wmake libso.
But I get the following error message:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file myoscillatingRotatingMotion.C
could not open file solidBodyMotionFunction.H for source file myoscillatingRotatingMotion.C
SOURCE=myoscillatingRotatingMotion.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/triSurface/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/dynamicMesh/lnInclude -I/opt/openfoam211/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/myoscillatingRotatingMotion.o
In file included from myoscillatingRotatingMotion.C:26:0:
myoscillatingRotatingMotion.H:38:37: fatal error: solidBodyMotionFunction.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/myoscillatingRotatingMotion.o] Error 1
What am I doing wrong?
Thanks allot,
Alex
Old   September 19, 2012, 08:27
Alexander A
I managed to compile my newApp library which comprises myoscillatingRotatingMotion.
The problem is I call multiMotion in my dynamicMeshdict file which should offer to use myoscillatingRotatingMotion. But when I run the case it comes an error which says valid solidBodyMotionFunctions for the multiMotion are ...and list the valid functions . This List doesen't comprise my oscillatingRotatingMotion.
What do I have to do that the multiMotion also offers to call myoscillatingrotatingMotion?
Best,
Alex
Old   September 19, 2012, 08:47
Alexander A
I made a mistake I forgot to put libs ("...") in the controlDict file.
After correcting this I get the following error in log.pimpleDyMFoam:
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1175
dlopen error : libnewApp.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
could not load "libnewApp.so"
Could the problem be that the location of my library is wrong? As I said I couldn't find $FOAM_USER_APPBIN on my PC and I put It in $WM_PROJECT_USER_DIR.
Best,
Alex
Old   September 19, 2012, 10:21
Alexander A
Got it in the end ! My function works.
It's all in the links from Bruno.
Many thanks,
Alex
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 gwierink OpenFOAM Installation 0 April 5, 2011 04:38
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
