How can I find the inverse of a sparse matrix
Like Tree2Likes
  • 2 Post By chegdan
Old   January 18, 2014, 17:10
Default How can I find the inverse of a sparse matrix
mechy is on a distinguished road
I have a matrix n*n and I want to find its inverse.
the matrix is not a 3 diagonal matrix (lower-upper- diagonal)and therefor I can not use the lduMatrix
any help will be appreciated
mechy is offline   Reply With Quote
Old   January 19, 2014, 10:47
Retired Super Moderator
Bruno Santos
Hi mechy,
I'm just dropping by to help future readers on where you found part of the solution to your problem and a link to another thread that is on a related topic:
Best regards,
Bruno
Old   January 19, 2014, 21:29
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
This is an incorrect assumption. lduMatrix can be used to represent a sparse matrix with any pattern**, not just 3 diagonals like you are assuming. The whole idea of the lduSolvers (preconditioned conjugate gradient, preconditioned bi-conjugate gradient, etc.) is to find the inverse of a sparse matrix, and also one of the key components of implicit finite volume methods. Your choice of algorithms depends on the system characteristics (mainly symmetric or asymmetric A, as in Ax=b ). The following threads may get you started at least with the storage format
If you want to look into the actual methods, i would look at the book "iterative methods for sparse linear systems" and the paper "An introduction to the conjugate gradient method without the agonizing pain". Good luck.
**much like CSR, CSC, ELL, and others...but some are better suited for certain sparse patterns
wyldckat and mechy like this.
chegdan is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
C++ solver for Large sparse matrix! sina_mech Main CFD Forum 7 November 20, 2009 13:52
Inverse of a matrix Sathe Main CFD Forum 5 May 15, 2002 16:01
sparse matrix solvers ahmed mobarki Main CFD Forum 3 August 30, 2000 22:06
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 04:22
