Boundary condition setting for adding gravity in simpleFoam |
February 8, 2013, 06:51 |
Bin Xu
Hi Foamers,
I am just starting simulation water flow in a horizontal circular pipe. Without adding gravity, it works well. With adding gravity, it can't converge. The result diverse and become unbelievable. I think problem might due to the boundary condition setting for p. I will list the step that I did for adding the gravity. Your kindly attention would be much appreciated. 1 I add g in the createFields.H as follows Info<< "Reading g\n" << endl; uniformDimensionedVectorField g ( IOobject ( "g", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); 2 I make change to UEqn.H eqnResidual = solve ( UEqn() == -fvc::grad(p)+g ).initialResidual(); 3 I make change to pEqn.H U -= (fvc::grad(p)-g)/AU; After that, I wmake to make these changes take effect. In the constant folder, the g file is listed as follow dimensions [0 1 -2 0 0 0 0]; value ( 0 0 -9.81 ); In the 0 folder, the p is setting as previous simulation which is without gravity dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } tubewall { type zeroGradient; } outlet { type fixedValue; value uniform 0; } plane { type symmetryPlane; } } |
boundary condition, convergence, gravity, simplefoam |
UDF setting wall boundary condition with a DEFINE_PROFILE | NLao | FLUENT | 3 | September 2, 2019 00:33 |
setting Boundary condition for additional variable | fek66 | CFX | 2 | May 19, 2011 04:44 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
