Boundary condition setting for adding gravity in simpleFoam
Old   February 8, 2013, 06:51
Unhappy Boundary condition setting for adding gravity in simpleFoam
Bin Xu
norkistar is on a distinguished road
Hi Foamers,
I am just starting simulation water flow in a horizontal circular pipe. Without adding gravity, it works well. With adding gravity, it can't converge. The result diverse and become unbelievable. I think problem might due to the boundary condition setting for p. I will list the step that I did for adding the gravity. Your kindly attention would be much appreciated.
1 I add g in the createFields.H as follows
Info<< "Reading g\n" << endl;
uniformDimensionedVectorField g
IOobject
"g",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
2 I make change to UEqn.H
eqnResidual = solve
UEqn() == -fvc::grad(p)+g
).initialResidual();
3 I make change to pEqn.H
U -= (fvc::grad(p)-g)/AU;
After that, I wmake to make these changes take effect.
In the constant folder, the g file is listed as follow
dimensions [0 1 -2 0 0 0 0];
value ( 0 0 -9.81 );
In the 0 folder, the p is setting as previous simulation which is without gravity
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
tubewall
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
plane
type symmetryPlane;
norkistar is offline   Reply With Quote
Old   February 14, 2013, 11:59
Mieszko Młody
ziemowitzima is on a distinguished road
I would suggest you to look into solvers where gravity is implemented, such as:
multiphase and heat transfer solvers.
ziemowitzima is offline   Reply With Quote
Old   February 15, 2013, 19:06
Bin Xu
Thanks for your kind attention. I have looked into the heat transfer solvers and I use buoyantSimpleFoam now it works
Old   June 15, 2022, 04:20
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Could you please share with us what you have done? Many thanks.
Mahmoud Abbaszadeh is offline   Reply With Quote
boundary condition, convergence, gravity, simplefoam
UDF setting wall boundary condition with a DEFINE_PROFILE NLao FLUENT 3 September 2, 2019 00:33
setting Boundary condition for additional variable fek66 CFX 2 May 19, 2011 04:44
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Warning 097- AB Siemens 6 November 15, 2004 04:41
