Getting node of a position
Like Tree2Likes
  • 2 Post By l_r_mcglashan
Old   March 2, 2013, 15:39
Default Getting node of a position
Mahdi Hosseinali
anishtain4 is on a distinguished road
How do you find the grid point that is near a location?
The purpose is to calculate space correlation of a turbulence field which means:
R(r)=<u(x)u(x+r)>/<u(x)^2>
anishtain4 is offline   Reply With Quote
Old   March 2, 2013, 23:28
Default The most easiest way
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I think the most easiest way to do your job is the following:
    vector pos(0.0,0.0,0.0); //Change the position as you like
    scalar limitLeng = 0.1;  //Change the value as you like
    const cellList& Cells = mesh.cells();
    const pointField& Points = mesh.points();
    forAll(Cells, cellI)
        if(mag(mesh.C()[cellI] - pos) < limitLeng)
            forAll(mesh.cellPoints()[cellI], pointi)
                //You can access labels of cell vertices
                label pointI = mesh.cellPoints()[cellI][pointi];
                scalar r = mag(pos - Points[pointI]);
                //your stuff
Please post the codes, if there are more efficient ways.
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   March 3, 2013, 07:37
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
The above code is unreliable, as the answer will be dependent on limitLeng. You are also not considering the situation where the nearest point to the location you are looking up may not be a part of the cell that it is inside of, although that will depend on how your mesh was constructed.
primitiveMesh has a findCell function. Use that instead.
If you want something more efficient then meshSearch uses an octree method for faster lookup. It doesn't work in parallel though so the location you lookup must be within the local mesh.
anishtain4 and fumiya like this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 12:36
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
License server not visible from master node Charles FLUENT 0 October 30, 2007 17:48
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
