warning when building a new solver
Old   February 25, 2013, 12:12
Default warning when building a new solver
Ye Zhang
kiddmax is on a distinguished road
Dear all,
When I build a new solver, after "wmake", there are some warnings as followed.However I can run the new solver, why do these warning come out? Do they matter?
Making dependency list for source file pisoFoam.C
SOURCE=pisoFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/transportModels -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pisoFoam.o
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nOuterCorr’
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:15: warning: unused variable ‘transonic’
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readTimeControls.H:32: warning: unused variable ‘adjustTimeStep’
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readTimeControls.H:35: warning: unused variable ‘maxCo’
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readTimeControls.H:38: warning: unused variable ‘maxDeltaT’
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/turbulenceModels/incompressible/turbulenceModel -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/transportModels -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/pisoFoam.o -L/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib \
-lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume
Could you give me some comments?
Best regards,
Ye
kiddmax is offline   Reply With Quote
Old   February 25, 2013, 17:28
Retired Super Moderator
Bruno Santos
Greetings Ye,
I'll quote myself from a post I made back in 2010 :
Originally Posted by wyldckat View Post
Those warnings are actually normal. AFAIK, those solvers use header files that are common to various solvers and not all solvers use those variables, therefore it triggers warning messages on those that don't use them.
Best regards,
Bruno
Old   February 26, 2013, 04:13
Ye Zhang
Bruno,
Thank you so much! I really appreciate that! By the way, can I ask you one more question? Now I want to simulate the unsteady flow of the 2D airfoil in stall condition with pisoFoam solver. In Openfoam, should I start the simulation from original initial value or from the converged result obtained from steady solver simpleFoam as Fluent?
Regards,
Ye
Old   February 26, 2013, 04:30
Bruno Santos
Hi Ye,
Not exactly the same topic... but OK, I think I know the answer:
  1. I think you can use pisoFoam directly, if you are willing to wait longer for the solution.
  2. If not willing to wait, I suppose you can use simpleFoam. Check the tutorials folder, "incompressible/pisoFoam" sub-folder and you should find a few examples on this topic!
Best regards,
Bruno
Old   February 27, 2013, 03:54
Ye Zhang
Hi, Bruno
Thank you for your quick reply. I will try it!
Regards,
Ye
[swak4Foam] installing funkySetFields prapanj OpenFOAM Community Contributions 65 October 8, 2015 17:46
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
