Adding source term involving derivative in y direction
Like Tree2Likes
  • 1 Post By iqbalsk8
Old   February 22, 2013, 12:51
Default Adding source term involving derivative in y direction
Sohail
iqbalsk8 is on a distinguished road
Hi everyone,
I want to add a new transport equation to simpleFoam.
The source term looks like Sw = nu/pow(y,2) * dw/dy
where y is the y-coordinate of the cell and
dw/dy is the derivative in the y-direction.
fvScalarMatrix UwEqn
fvm::div(phi, w)
- fvm::laplacian(nu, w)
- Sw
My confusion is to get the derivative in a one direction not to calculate the
whole gradient.
Can anybody give me an idea how to achieve this.
regards,
Sohail
Luttappy likes this.
iqbalsk8 is offline   Reply With Quote
Old   February 22, 2013, 14:10
Mahdi Hosseinali
anishtain4 is on a distinguished road
If i'm correct you may get the gradient only in the explicit way which would be:
vectorField gradU=fvc::grad(w)
then you can extract the desired component by:
scalarField dwdy=gradU.component(vector::Y)
I may not be correct in spelling or own the best way, but this should work
anishtain4 is offline   Reply With Quote
Old   February 24, 2013, 08:31
Sohail
Dear Hosseinali,
Thankyou for giving time to answer. I also thought the same and
it works fine.
But now I have another problem. I have a term
Sw = (Uy * w)/y
where Uy is the y component of velocity
and y coordinate.
Can this term be put in UwEqn as,
fvm::Sp(Uy/y, w)
where Uy=U.component(vector::Y)
Best regards,
Sohail
Old   February 25, 2013, 04:20
Mahdi Hosseinali
Just from the top of my head, when you are using the SIMPLE every equation is being solved separately, also in source term of your equation for UwEqn there is no Uw (Uy is being considered known from previous step) so I think there would be no difference if you use fvm or mention it explicitly
Old   February 25, 2013, 09:30
Sohail
Dear Hosseinali,
I tried to put the term
Sw = (Uy * w)/y
with fvm::Sp and explicitely. but in both cases the value of Sw tends to infinity
after 500 iterations approximately.
I am using OpenFOAM-1.6-ext. I am simulating a 2D axisymmetric case.
Where this new transport equation calculates the swirl-component
of velocity.
Please have a look at the file.
If you want the whole case file, I can also send you that...
regards,
Sohail
File Type: h wEqn.H (637 Bytes, 47 views)
Old   March 2, 2013, 10:39
Mahdi Hosseinali
I'm not sure how this affects your stability, All I'm saying is that with the solver you chose this term would have same effect explicitly or implicitly on the solution.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 15:00
derivative of source term denise Fluent UDF and Scheme Programming 1 October 29, 2009 04:41
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 09:15
