acc
Old   March 6, 2013, 23:22
Default acc
Nikesh Bhattarai
nikesh is an unknown quantity at this point
It sometimes gets me confused whether I'm at the right place for my questions. However, here it goes....
I need to access the source code of SIMPLE algorithm in OpenFOAM. Where do I look?
Secondly, after going into the source code, I'll need to understand one of the functions used there. For eg, there's a piece of code that reads as::
eqnResidual = solve ( UEqn() == -fvc::grad(p) ).initialResidual();
Now, I need to find out how initialResidual is determined/calculated inopenFOAM (simpleFoam),how and where do I look for it ??
Is there any command that I can use in the terminal that'll direct me where that particular function is located?
Any heads up highly appreciated.
Thnx!!
nikesh
nikesh is offline   Reply With Quote
Old   March 7, 2013, 02:33
Bernhard
Bernhard is on a distinguished road
You could either use the Doxygen files: http://www.openfoam.org/docs/cpp/ this brings you to: http://foam.sourceforge.net/docs/cpp...ce.html#l00173
Or you could use grep and find from the src directory
grep initialResidual $(find -name \*.C -or -name \*.H)
Bernhard is offline   Reply With Quote
Adding graviational acc. to turbulence model fertinaz OpenFOAM Programming & Development 6 December 12, 2020 00:04
vortex induced vibration Simon Wang FLUENT 4 December 25, 2017 03:23
OpenFOAM vs Fluent for cylinder at Re%3d150 lr103476 OpenFOAM Running, Solving & CFD 40 December 18, 2008 09:09
Differences OpenFOAM12 and OpenFOAM13 lr103476 OpenFOAM Running, Solving & CFD 43 July 22, 2008 16:46
Accessing the angle of a cyclicPolyPatch make OpenFOAM Running, Solving & CFD 0 February 5, 2008 09:02
