problem in adding dissipation term to T equation!!! |
May 10, 2013, 01:58 |
Hi everybody,
I want to add the dissipation term to my T equation. I did it as follows: Code:
dimensionedScalar kappa=(etaS+etaP)/(rho*Pr); fvScalarMatrix TEqn ( fvm::div(phi, T) - fvm::Sp(fvc::div(phi), T) - fvm::laplacian(kappa, T) - (visco.tau() && (fvc::curl(U))) //Dissipation Term ); when I wmake my solver the following errros appeared: Code:
In file included from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C:735:0, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.H:360, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:39, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/primitiveFields.H:37, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/pointField.H:36, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/edge.H:40, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/edgeList.H:32, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/primitiveMesh.H:57, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/polyMesh.H:44, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMesh.H:50, from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvCFD.H:7, from bbvffPerfectTdepDiss2.C:36: /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C: In function ‘void Foam::dotdot(Foam::Field<typename Foam::scalarProduct<Type1, Type2>::type>&, const Foam::UList<T>&, const Foam::UList<Key>&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, typename Foam::scalarProduct<Type1, Type2>::type = double]’: /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:956:1: instantiated from ‘void Foam::dotdot(Foam::GeometricField<typename Foam::scalarProduct<Type1, Type2>::type, PatchField, GeoMesh>&, const Foam::GeometricField<TypeR, PatchField, GeoMesh>&, const Foam::GeometricField<Type1, PatchField, GeoMesh>&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::scalarProduct<Type1, Type2>::type = double]’ /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:956:1: instantiated from ‘Foam::tmp<Foam::GeometricField<typename Foam::scalarProduct<Type1, Type2>::type, PatchField, GeoMesh> > Foam::operator&&(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::scalarProduct<Type1, Type2>::type = double]’ TEqn.H:22:38: instantiated from here /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C:705:1: error: no match for ‘operator&&’ in ‘*(f2P ++) && *(f3P ++)’ /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C:705:1: note: candidates are: operator&&(bool, bool) <built-in> /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionSet.H:293:29: note: Foam::dimensionSet Foam::operator&&(const Foam::dimensionSet&, const Foam::dimensionSet&) make: *** [Make/linuxGccDPOpt/bbvffPerfectTdepDiss2.o] Error 1 thanks Mostafa |
June 25, 2015, 02:14 |
add the dissipation term to TEqn
Qingwu Xiao
Hi Mostafa,
I have the same problem. I add the dissipation term[ - (visco.tau() && (fvc::grad(U)))] to TEqn, when I wmake the solver , the following errros appeared just as your problem. Did your solution solve the problem? I am a newbie in this field, could you give me tips how could I implement it. Thanks in advance. pashanxiao |
June 25, 2015, 03:05 |
#3 | |
It's for 2 years ago and I can't remember what had I done Perhaps I've expanded the dissipation term and added it term-by-term. Regards, Mostafa |
Adding source term to the momentum equation | sirpolar | FLUENT | 1 | January 6, 2016 08:29 |
Problem adding a source term in interfoam's alphaEqn.H | Quentin | OpenFOAM Running, Solving & CFD | 1 | July 30, 2014 05:33 |
turbulent diffusion term in transport equation for additional variables | Raijin Thunderkeg | CFX | 2 | May 17, 2014 22:53 |
Adding a new term in momentum equation of Interfoam | udiitm | OpenFOAM | 5 | July 29, 2012 10:52 |
how to troduce a source term in ICOFOAM solver's equation | sawyer86 | OpenFOAM Running, Solving & CFD | 0 | July 20, 2012 11:15 |
