problem in adding dissipation term to T equation!!!
Old   May 10, 2013, 01:58
Default problem in adding dissipation term to T equation!!!
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
I want to add the dissipation term to my T equation. I did it as follows:
    dimensionedScalar kappa=(etaS+etaP)/(rho*Pr);
    fvScalarMatrix TEqn
        fvm::div(phi, T)
      - fvm::Sp(fvc::div(phi), T)
      - fvm::laplacian(kappa, T)
      - (visco.tau() && (fvc::curl(U)))  //Dissipation Term
where visco is my viscoelastic model and visco.tau is a symmetric tensor.
when I wmake my solver the following errros appeared:
In file included from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C:735:0,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.H:360,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/labelField.H:39,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/primitiveFields.H:37,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/pointField.H:36,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/edge.H:40,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/edgeList.H:32,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/primitiveMesh.H:57,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/polyMesh.H:44,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMesh.H:50,
                 from /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvCFD.H:7,
                 from bbvffPerfectTdepDiss2.C:36:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C: In function ‘void Foam::dotdot(Foam::Field<typename Foam::scalarProduct<Type1, Type2>::type>&, const Foam::UList<T>&, const Foam::UList<Key>&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, typename Foam::scalarProduct<Type1, Type2>::type = double]’:
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:956:1:   instantiated from ‘void Foam::dotdot(Foam::GeometricField<typename Foam::scalarProduct<Type1, Type2>::type, PatchField, GeoMesh>&, const Foam::GeometricField<TypeR, PatchField, GeoMesh>&, const Foam::GeometricField<Type1, PatchField, GeoMesh>&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::scalarProduct<Type1, Type2>::type = double]’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:956:1:   instantiated from ‘Foam::tmp<Foam::GeometricField<typename Foam::scalarProduct<Type1, Type2>::type, PatchField, GeoMesh> > Foam::operator&&(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, typename Foam::scalarProduct<Type1, Type2>::type = double]’
TEqn.H:22:38:   instantiated from here
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C:705:1: error: no match for ‘operator&&’ in ‘*(f2P ++) && *(f3P ++)’
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FieldFunctions.C:705:1: note: candidates are: operator&&(bool, bool) <built-in>
/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/dimensionSet.H:293:29: note:                 Foam::dimensionSet Foam::operator&&(const Foam::dimensionSet&, const Foam::dimensionSet&)
make: *** [Make/linuxGccDPOpt/bbvffPerfectTdepDiss2.o] Error 1
anybody knows where is the problem? I'm completely confused.
thanks
Mostafa
adambarfi is offline   Reply With Quote
Old   June 25, 2015, 02:14
Default add the dissipation term to TEqn
Qingwu Xiao
pashanxiao is on a distinguished road
Hi Mostafa,
I have the same problem. I add the dissipation term[ - (visco.tau() && (fvc::grad(U)))] to TEqn, when I wmake the solver , the following errros appeared just as your problem. Did your solution solve the problem?
I am a newbie in this field, could you give me tips how could I implement it.
Thanks in advance.
pashanxiao
pashanxiao is offline   Reply With Quote
Old   June 25, 2015, 03:05
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by pashanxiao View Post
Hi Mostafa,
Thanks in advance.
pashanxiao
Greetings Qingwu,
It's for 2 years ago and I can't remember what had I done
Perhaps I've expanded the dissipation term and added it term-by-term.
Regards,
Mostafa
Adding source term to the momentum equation sirpolar FLUENT 1 January 6, 2016 08:29
Problem adding a source term in interfoam's alphaEqn.H Quentin OpenFOAM Running, Solving & CFD 1 July 30, 2014 05:33
turbulent diffusion term in transport equation for additional variables Raijin Thunderkeg CFX 2 May 17, 2014 22:53
Adding a new term in momentum equation of Interfoam udiitm OpenFOAM 5 July 29, 2012 10:52
how to troduce a source term in ICOFOAM solver's equation sawyer86 OpenFOAM Running, Solving & CFD 0 July 20, 2012 11:15
