meaning of HbyA
Like Tree37Likes
  • 1 Post By Tobi
  • 31 Post By Cyp
  • 4 Post By Cyp
  • 1 Post By ooo
Old   June 6, 2013, 14:14
Default meaning of HbyA
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I am not clear about the variable HbyA
volVectorField HbyA("HbyA", U);
HbyA = rAU*UEqn().H();
Can someone tell me what that variable is for?
In the 1.6-ext version I found the same declaration:
U = rUA*UEqn().h();
So I think its the same, but why the different names?
Thanks in advance
Tobi
nepomnyi likes this.
Tobi is offline   Reply With Quote
Old   June 6, 2013, 16:07
Cyp
Cyprien
Cyp is on a distinguished road
Dear Toby,
As you noticed, both lines are similiar. Actually, the notation HbyA has been spread over all the solvers since the latest OF version (OF 2.2.0) for a sake of clarity.
Keep in mind that for the computation of Naviers-Stokes equation, OF uses either PISO or SIMPLE algorithms. The semi-discretized form of the momentum is :
a_{P} \textbf{U}_{P} = \textbf{H}(\textbf{U}) - \nabla p
where a_{P} is the diagonal coefficients of the matrix resulting from the discretization of the momentum equation. \textbf{H}(\textbf{U}) stands for the non-diagonal coefficient (mainly composed by convective and diffusive terms) and the source terms (the source part of the transient term and other source that appear in UEqn) apart from the pressure gradient.
Once this equation has been implicitly solved (the momentum predictor step), the predicted velocity does not satisfy the continuity equation. Moreover, in the previous equation, the pressure field result from the previous time step. Therefore, we are looking for (U,p) that obeys
\textbf{U}_{P} = \frac{\textbf{H}(\textbf{U})}{a_{P} } - \frac{1}{a_{P} } \nabla p
and
\nabla \cdot \textbf{U}_{P} = 0
Assembling this two equations, you can form the pressure equation:
\nabla \cdot \left( \frac{1}{a_{P}}\nabla p \right) = \nabla \cdot \left(\frac{\textbf{H}(\textbf{U})}{a_{P} }   \right)
and then you reconstruct the velocity with:
You clearly remark in this procedure that you use H divided by A or.. HbyA ;-)
PS: in OF, rAU is the notation for the diagonal coeff of the matrix
Best regards,
Cyp
Tushar@cfd, Tobi, armyou and 28 others like this.
Cyp is offline   Reply With Quote
Old   June 6, 2013, 16:23
Cyp
Cyprien
I made slides some times ago to explain the PISO loops in OpenFOAM : http://fr.scribd.com/doc/143414962/P...on-in-OpenFOAM
They are in French but understandable. It uses old OpenFOAM version, that means without the HbyA notation.
Old   July 5, 2013, 02:45
Dongyue Li
sharonyue is on a distinguished road
Best regards,
Cyp
Hi, about this, why it is not
fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(rAU&HbyA)
Thanks in advance.
sharonyue is online now   Reply With Quote
Old   July 5, 2013, 06:24
Tobi's Avatar
Tobias Holzmann
Hi all,
as I understand from Cyp 's comment:
\frac{\bf{H}(U)}{a_P} = \text{HbyA}
So your last line should be:
fvScalarMatrix pEqn
                    xxx == fvc::div(HbyA)
I am not able to have a look into the code at the moment.
Old   November 15, 2013, 15:30
Cyp
Cyprien
the same doc, in English with OF2.2
http://www.scribd.com/doc/181588911/...ion-of-icoFoam
dokeun, Tobi, pixarzhang and 1 others like this.
Old   December 24, 2013, 02:41
Default thx
enzhen zhang
pixarzhang is on a distinguished road
it's very clear for me
pixarzhang is offline   Reply With Quote
Old   March 14, 2014, 15:26
ooo
ooo is on a distinguished road
Dear Guys,
I'm using the 3step runge-kutta scheme to solve Navier Stokes equation.
There are some differences in the equations must be solved, but the main equations are same.you can see the equations in the attachment(those equations are put in a for loop, from k=1 to k=3)
Also, below you can see my summarized code to solve that, but i don't know how to use coefficients(same as piso loop of icoFoam) !
I would appreciate any idea on how to change my code to something like the piso loop of icoFoam :
while (runTime.loop())
for (int i = 1 ;  i<=3 ; ++i)
U = U + runTime.deltaT() *
         + 2*alpha*fvc::laplacian(nu,U)
         - 2*alpha*fvc::grad(p)
         - gamma*fvc::div(phi, U)
         - zeta*fvc::div(phiOld2, UOld2)
      solve(alpha*runTime.deltaT()*fvm::laplacian(nu,Unew) - fvm::Sp(1.,Unew)  == //(alpha*runTime.deltaT())  ==
      (-1.)*(U) + alpha*runTime.deltaT()*fvc::laplacian(nu,U) );
      solve (fvm::laplacian(pPhi) == fvc::div(U)/(2.*alpha*runTime.deltaT()));// pPhi is a pseudo pressure without physical meaning
      U =  Unew - (2.*alpha*runTime.deltaT()*fvc::grad(pPhi));
      p += pPhi - alpha*runTime.deltaT()*nu*(fvc::laplacian(pPhi));
      adjustPhi(phi, U, p);
      U.correctBoundaryConditions();
} //alpha,gamma and zeta change in each of those 3 steps
hua1015 likes this.
ooo is offline   Reply With Quote
Old   March 27, 2016, 06:17
Saideep
Saideep is on a distinguished road
Thanks guys for sharing this information!!
I am just going through the implementation of PISO/ PIMPLE in interFoam solver. I could understand and link most part of what is discussed here but confused at parts.
Hope you can help me out!!
Starting with UEqn.H:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
+ turbulence->divDevRhoReff(rho, U)
fvOptions(rho, U)
Over here we already have a solution for velocity without influence of pressure.{solving NSE excluding variables of pressure and body forces that dont have an explicit U term}. We extract the diagonal{UEqn.A()} and off- diagonal portions {UEqn.H()}.
Now passing to pEqn.H:
We find and link velocity to flux over cell faces.(U -> phi)
Additionally due to surface tension force induced flux, we add flux to the above calculated flux. {Even here pressure isnt included till now}.
Now the pressure corection is directly applied as follows:
fvm::laplacian(rAUf, p_rgh) == fvc::div(phiHbyA)
/*we are finding for p_rgh*/
From this further correction to flux and U from the found out pressure is calculated to get the conservative velocity.
My question,
1. In all explanations I have had browsed through, they explicitly mention usage of pressure twice. One as an approximate and one found as a real value.
But from interFoam solver I see only once the usage of pressure and it is the corrected pressure that we are solving for. {above equation, laplacian pressure}
2. What are nOuterCorrectors, nCorrectors variablels? I see their default definitions but where are we specifying the loop? I guess it has something to do with pimple.correct() loop but how are the variables being used?
Thanks and interested to hear your views,
Saideep
Saideep is offline   Reply With Quote
Old   March 27, 2016, 18:24
Tobi's Avatar
Tobias Holzmann
For nouter and ncorr See my blog
Keep foaming,
Tobias Holzmann
Meaning of Ychar and Ypmma aylalisa OpenFOAM Pre-Processing 2 October 20, 2013 05:49
what is the meaning of this?!??!!? adambarfi OpenFOAM Running, Solving & CFD 9 September 13, 2013 10:53
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 08:04
want to know meaning Sangamesh Siemens 0 May 15, 2007 05:15
What's the meaning of "combustion scalar"and.... cfdbeginner CFX 0 November 27, 2003 09:02
