Difference between UEqn in sonicFoam & Theory
Like Tree5Likes
  • 1 Post By sasanghomi
  • 1 Post By vwibaut
  • 2 Post By vwibaut
Old   June 14, 2013, 18:13
Default Difference between UEqn in sonicFoam & Theory
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Foamers ,
I found a difference between UEqn in sonicFoam and Ferziger's book (Computational Methods for fluid Dynamics ).
In the code for UEqn in sonicFoam we have :
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
    + fvm::div(phi, U)
    + turbulence->divDevRhoReff(U)
solve(UEqn == -fvc::grad(p));
This code ensures below equation :
\frac{\partial \rho u_{i}}{\partial t} + \frac{\partial \rho u_{i}u_{j}}{\partial x_{j}} = -\frac{\partial p}{\partial x_{i}} + \frac{\partial }{\partial x_{j}} (\mu _{eff}(\frac{\partial u_{i}}{\partial x_{j}} + \frac{\partial u_{j}}{\partial x_{i}})) - \frac{2}{3}\mu _{eff}\frac{\partial }{\partial x_{j}} (\frac{\partial u_{k}}{\partial x_{k}}\delta _{ij})
But in the Ferziger's book (generally in theory) there is another equation :
\frac{\partial \rho u_{i}}{\partial t} + \frac{\partial \rho u_{i}u_{j}}{\partial x_{j}} = -\frac{\partial p}{\partial x_{i}} + \frac{\partial }{\partial x_{j}} (\mu _{eff}(\frac{\partial u_{i}}{\partial x_{j}} + \frac{\partial u_{j}}{\partial x_{i}})) - \frac{2}{3}\frac{\partial }{\partial x_{j}} (\rho k \delta _{ij})-\frac{2}{3}\frac{\partial }{\partial x_{j}}(\mu _{eff}\frac{\partial u_{k}}{\partial x_{k}}\delta _{ij})
The last term in two equations are different . Please guide me that what is the origin of this difference ? And please correct me if I am wrong.
I appreciate any help from you.
Thanks and best regards,
Sasan.
immortality likes this.
sasanghomi is offline   Reply With Quote
Old   June 26, 2013, 09:20
Valentin Wibaut
vwibaut is on a distinguished road
Your ferziger's equation comes from incompressible theory, no? You haven't any term
dui/dxi
vwibaut is offline   Reply With Quote
Old   June 26, 2013, 11:25
immortality's Avatar
Ehsan
immortality is on a distinguished road
I think so
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 27, 2013, 01:34
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Dear sasanghomi,
I found the same incongruence some time ago. I think that is a bug, but if you have some time you can review the
 divDevRhoReff
member function to try to figure out this problem. I try to do this, but my conclusion was that it is an error, because the term
\frac{2}{3}\bar{\rho}\widetilde{k}\mathcal{I}
is missing
Best regards.
Felipe G.
Felipe G
lfgmarc is offline   Reply With Quote
Old   June 27, 2013, 02:54
Valentin Wibaut
Originally Posted by lfgmarc View Post
Dear sasanghomi,
 divDevRhoReff
is missing
Best regards.
Felipe G.
The term with 2/3 rho k is present in the equation. It is taken into account in the pressure (in the equation p = ps + 2/3 rho k). The results you have, after simulations, give you a pressure wich contains the real pressure and turbulent kinetic energy.
Old   June 27, 2013, 03:09
Christian Lucas
Chris Lucas is on a distinguished road
have a closer look at the function:
divDevRhoReff
and you will find your "missing" term
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   June 27, 2013, 03:48
lfgmarc's Avatar
Hi to all,
Can you say me the OF version ? because at least in OF1.7.0 I can't find this term.
http://www.cfd-online.com/Forums/ope...sonicfoam.html
Maybe I looked in a wrong location in the code.
sonicFoam pressure equation.
rho = thermo.rho();
volScalarField rUA = 1.0/UEqn.A();
U = rUA*UEqn.H();
surfaceScalarField phid
    "phid",
    fvc::interpolate(psi)
        (fvc::interpolate(U) & mesh.Sf())
      + fvc::ddtPhiCorr(rUA, rho, U, phi)
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
    fvScalarMatrix pEqn
        fvm::ddt(psi, p)
      + fvm::div(phid, p)
      - fvm::laplacian(rho*rUA, p)
    pEqn.solve();
    if (nonOrth == nNonOrthCorr)
        phi = pEqn.flux();
#include "rhoEqn.H"
#include "compressibleContinuityErrs.H"
divDevRhoReff kEpsilon :
tmp<fvVectorMatrix> kEpsilon::divDevRhoReff(volVectorField& U) const
    return
      - fvm::laplacian(muEff(), U)
      - fvc::div(muEff()*dev2(fvc::grad(U)().T()))
Thanks in advance.
Best regards.
Felipe G
Old   June 27, 2013, 03:50
Sasan Ghomi
Hi Guys ,
I corrected the momentum equation in first post (Theory equation). But I think below term is missed.
Best regards
sasan.
lfgmarc likes this.
Old   June 27, 2013, 03:56
Sasan Ghomi
Hi Valentin ,
Which file have this equation for pressure ?
Can you explain more and clarify the issue ?
Sasan.
Old   June 27, 2013, 04:12
Valentin Wibaut
You will not find this term because it is into the pressure term. More clearly, the pressure in your equation isn't the real pressure. It is the real pressure+ 2/3 rho k.
But it is close to the real pressure because k << p
lfgmarc and sasanghomi like this.
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 00:15
A question about UEqn sonicFoam lfgmarc OpenFOAM Programming & Development 6 February 1, 2015 16:49
sonicFoam not matching shock theory Alan OpenFOAM Running, Solving & CFD 15 June 27, 2013 07:10
Source term problem in UEqn of simpleFoam fisch OpenFOAM Programming & Development 1 June 17, 2011 10:57
Difference between codes and representations titio OpenFOAM Running, Solving & CFD 3 July 3, 2009 07:58
