Define steam flow rate
Old   June 27, 2013, 07:24
Default Define steam flow rate
belkadi
belkadi is on a distinguished road
Dear FOAMers,
I'm trying to train myself with OpenFoam, I've created a simple example :
Idefined a simple geomtry (square tank) filled with water.
I would like to define an inlet for the steam flow rate in the bottom of my tank to see the effect on mixing, I suppose that the interFoam is a good candidate to solve this problem.
setFields is important to define the problem: deos any one knows how to define this ?
I have defined my inlet in blockMeshDict, U file to define the flowrate of the inlet by :
inlet
type flowRateInletVelocity;
massFlowRate constant 0.1;
rhoInlet 1;
How could I define the flowrate in the setFields ? Or is something missing to define my flowrate inlet ?
If any one can help to how to do to define the steam injection will be great !
Thank you in advance !
Krimo
belkadi is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
How to define mass flow rate using UDF? SAMUEL FLUENT 0 December 16, 2004 02:55
