February 26, 2024, 11:13 |
Spurious Current in 2024
Rep Power: 9 |
Hello all,
I'm trying to simulate surface tension dominating flow (water-air) and the dimension is about 10 micrometer. The stock interFoam is OK, but the time step is extremely small, making 3D simulation impossible. I did some research in this forum, and found 2 code repositories to deal with spurious current. 1. poreFoam https://github.com/ImperialCollegeLondon/porefoam This repo focuses on porous media and I couldn't find a way to simulate regular multiphase flow. I can't understand foam-extend language, it's very different from modern OpenFOAM, and I failed to port it to OF-v2312. 2. interFoamSSF https://github.com/aliozel/interFoamSSF/tree/master I spent quite a lot time to port this solver to OF-v2312, and found it's worse than stock interFoam. Is there more public repo that focuses on regular multiphase flow? Thanks. |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
Tutorials not working | abby10 | SU2 Installation | 1 | December 28, 2021 06:35 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
How to set current | Jendge | FLOW-3D | 3 | November 25, 2014 18:48 |
What is the difference between current time step and current time | djing | FLUENT | 4 | May 1, 2012 16:18 |
