build my own multi-region solver : pb with flux continuity
Old   January 28, 2013, 03:52
Default build my own multi-region solver : pb with flux continuity
Cyp
Cyprien
Cyp is on a distinguished road
Hi !
I am currently trying to develop my own multi-region solver. For sake of simplicity, let's say I have two regions, a "solid" and a "fluid". I want to solve heat transfers in both regions, with continuity and flux continuity at the solid/fluid interface.
fvScalarMatrix TsEqn
    fvm::laplacian(DTs,Ts)
TsEqn.solve();
fvScalarMatrix TfEqn
    fvm::laplacian(DTf,Tf)
TfEqn.solve();
Basically, I defined a solid_to_fluid and a fluid_to_solid patch to patch interpolation
    patchToPatchInterpolation solid_to_fluid
        solidMesh.boundaryMesh()[labelSolid],
        fluidMesh.boundaryMesh()[labelFluid]
    patchToPatchInterpolation fluid_to_solid
        fluidMesh.boundaryMesh()[labelFluid],
I apply successfully the value of Ts at the solid/fluid interface as a boundary condition for Tf :
    scalarField &TsP = Ts.boundaryField()[labelSolid];
    scalarField &TfP = Tf.boundaryField()[labelFluid];
    TfP = solid_to_fluid.faceInterpolate(TsP);
This part is ok.
My problem concern the flux continuity at the region interface. I want to apply the flux continuity imposing the solid temperature gradient at the interface with
    vectorField n = fluidMesh.boundary()[labelFluid].nf();
    volVectorField gradTf = DTf/DTs*fvc::grad(Tf);
    scalarField nGradTf = n & gradTf.boundaryField()[labelFluid] ;
    fixedGradientFvPatchScalarField& gradTsPatch=refCast<fixedGradientFvPatchScalarField>(Ts.boundaryField()[labelSolid]);
    scalarField& gradTsField =  gradTsPatch.gradient();
    gradTsField = p2_to_p1.faceInterpolate(nGradTf);
However it fails to have good result, and I can't have flux continuity. Is someone have an idea to solve my problem ?
best regards,
Cyp
Cyp is offline   Reply With Quote
Old   November 27, 2013, 08:38
styleworker is on a distinguished road
There is a multiregion solver available:
http://www.cfd-online.com/Forums/ope...eheatfoam.html
styleworker is offline   Reply With Quote
Old   November 27, 2013, 12:19
Cyp
Cyprien
Yes I worked on its basis.
Actually, to solve the "problem" I mentionede above, one need to under-relax the flux boundary condition, and iterate until convergence.
MRFSimpleFoam wind turbine case continuity error ysh1227 OpenFOAM Running, Solving & CFD 1 August 16, 2016 09:25
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
Build your own CFD solver Govert de With Main CFD Forum 9 December 12, 2001 05:51
