December 14, 2013, 06:13 |
static int debug
#1 | |
Rep Power: 14 |
hi,bool Foam:: pimpleControl::loop()
inter alia in method "bool Foam:: pimpleControl::loop()" can be found a variable called "debug" within the first if condition: Code:
bool Foam::pimpleControl::loop() //Implements solutionControl. 174*{ 175* read(); 176* 177* corr_++; //label corr_ protected, Current corrector loop index. //Class solutionControl 178* 179* if (debug) //static int debug, Debug Switch , fvSchemes ? 180* { 181* Info<< algorithmName_ << " loop: corr = " << corr_ << endl; 182* } . . . Quote:
greetings maybee |
Problem with pow and volScalarField | _Stefan_ | OpenFOAM Programming & Development | 15 | April 14, 2019 22:20 |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP | 4xF | OpenFOAM Bugs | 3 | October 16, 2009 05:35 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
