parabolic inlet velocity condition
Like Tree1Likes
  • 1 Post By ofslcm
Old   March 26, 2012, 15:19
Unhappy parabolic inlet velocity condition
solOF
ofslcm is on a distinguished road
I'm trying to program a parabolic inlet velocity condition with openFOAM-2.0 for a 3D channel. My function is:
U(0,y,z)=U*y*z*(H-y)/H^4
where U=U(0,H/2,H/2,t)
and H is the height of the channel.
I've copied
parabolicVelocityFvPatchVectorField.C
parabolicVelocityFvPatchVectorField.H
on
~/OpenFoam/OF-Org-2.0/OpenFOAM-2.0.0/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/.
and now I'm trying to modify this file, but I don't know how I can get U=U(0,H/2,H/2,t)
Could you help me please? Or could you give me a piece of advice to do it on a different way?
Thank you!
solOF
solefire likes this.
ofslcm is offline   Reply With Quote
Old   March 26, 2012, 16:18
Assistant Moderator
Bernhard Gschaider
Originally Posted by ofslcm View Post
I've copied
on
Thank you!
solOF
Not sure which parabolicVelocityFvPatchVectorField.C/H you're referring to. Maybe the ones discussed in
http://www.cfd-online.com/Forums/ope...ion-1-7-a.html
(which gives you pointers at two alternate approaches)
Old   March 27, 2012, 04:35
solOF
Thank you for the fast reply!
I'm going to use groovyBC, however I still don't know how I could define the velocity Um of my function:
U(0,y,z)=Um*y*z*(H-y)/H^4
where Um=U(0,H/2,H/2,t)
could you help me, please?
Thank you!
Old   March 27, 2012, 14:45
Assistant Moderator
Bernhard Gschaider
Thank you!
I see from http://www.cfd-online.com/Forums/ope...tml#post351786 that you already found that information.
Just one remark: I don't know what you want to acomplish with U@in: if it is to access a remote patch: the syntax has changed in swak4Foam. Also: in your case it is not required: variables are calculated on patch "in" anyway
Old   March 27, 2012, 19:10
solOF
thank you! What I want to do is to take U(0,H/2,H/2) from the "in" patch. I thought that it was a possible way to do that, but I'm not sure... It seems to be wrong, doesn't it?
I think that what you told me is that I should install swak4Foam and then I should implement the function:
U(0,y,z)=Um*y*z*(H-y)*(H-z)/h^4
V=0
W=0
where Um=4*U(0,H/2,H/2,t)
on that way:
in
type groovyBC;
variables "yp{in}=pts().y;zp{in}=pts().z;minZ=min(zp);maxZ=m ax(zp);H =(maxZ-minZ)/2;v{in}=4*v(0,H,H);";
valueExpression "vector(v*yp*zp*(H-yp)*(H-zp)/pow(H,4),0,0)";
Am I wrong?
Thank you very much
Old   March 27, 2012, 19:34
Assistant Moderator
Bernhard Gschaider
V=0
W=0
on that way:
in
type groovyBC;
Am I wrong?
Thank you very much
You can skip the {in} with variables. You're on the patch and variables therefor "live" there anyway
Old   April 7, 2012, 10:40
solOF
Thank you for your help,
Finally groovyBC is working. I have changed the extension ".so" by ".dylib" and now OpenFoam is able to find the library.
Now I have a different problem. I have program the boundary conditions on that way:
in
type groovyBC;
variables "yp=pts().y;zp=pts().z;minZ=min(zp);maxZ=max(zp);m inY=min(yp);maxY=max(yp);Hz=(maxZ-minZ)/2;Hy=(maxY-minY)/2;v=4*U(0,Hy,Hz)/9;";
valueExpression "vector(16*v*yp*zp*(Hy-yp)*(Hz-zp)/pow(H,4),0,0)";
I want to extract the velocity in (0,Hy,Hz), but it seems that I have a syntax error and I get:
--> FOAM FATAL ERROR:
Parser Error at "1.3" :"syntax error, unexpected '(', expecting $end"
"4*U(0,Hy,Hz)/9"
From function parsingValue
in file PatchValueExpressionDriver.C at line 192.
FOAM exiting
How can I extract the velocity in that point?
Thank you
Ofslcm
Old   April 9, 2012, 17:39
Assistant Moderator
Bernhard Gschaider
Do I get this right: you're on a Mac and to get it to work you have to replace .so with .dylib? Which patches/version are you using on the Mac. Because the patches I published for the Mac do this on the fly (they find .so in the library name and replace it) otherwise I would get crazy switching my cases from Mac to Linux ... and back
in
type groovyBC;
"4*U(0,Hy,Hz)/9"
FOAM exiting
Thank you
Ofslcm
The syntax of the expressions does not support getting the value of a function on a location. But there is a workaround
But first: you're sure you want to make the BC depend on the current solution? I just ask because there are all kinds of ways that this kind of feedback can make your simulation instable
The workaround would be to define a sampled set at the location in question (for instance named probe). Then you can use it in the variables as "v{set'probe}=4*U/9;" (U is the value at the probe location). The only downside is that the location of the probe currently can't be calculated (for details on using that see either the fillingTheDam case in the swak-Examples or the presentation from last years workshop)
Old   April 11, 2012, 12:16
solOF
the version that I'm using of OpenFOAM is 2.0. But I don't know why it doesn't recognize the extension ".so".
Thank you for your answer. I've been having a look to the fillingTheDam example. As you told me, I can program it to get U(0,H,H) doing this:
in
type groovyBC;
value uniform(0,0,0);
valueExpression "((pos().y==(max(pos().y)+min(pos().y)/2) && pos().z==(max(pos().z)+min(pos().z)/2)) ? -normal() : vector(0,0,0))";
storedVariables(
name probe;
initialValue "0";
variables(
However, I get the following error:
--> FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 77
Reading ./cylinder_00/0/U
found on line 58 the punctuation token ')'
expected either } or EOF
--> FOAM FATAL IO ERROR:
ill defined primitiveEntry starting at keyword 'variables(' on line 60 and ending at line 70
file: ./cylinder_00/0/U at line 70.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 165.
FOAM exiting
Why?
On the other hand, I'm interested in defining:
Is it possible to define 2 valueExpression? One with the conditional sentence followed by another one with this vector expression?
Thank you
Old   April 11, 2012, 15:42
Assistant Moderator
Bernhard Gschaider
But you're on a Mac (that was the reason for the dylib/so-business). Usually you'll have to patch OF to compile on a Mac. Did you do that yourself or did you get it from somewhere else?
in
type groovyBC;
storedVariables(
name probe;
initialValue "0";
variables(
--> FOAM Warning :
FOAM exiting
Why?
Have a look at the error message. OF thinks that variables( is a keyword. A space in the right place might do wonders
A note about the expression: == hardly ever works with floating point. You'd better check that the value is within a (small) range
Thank you
I don't understand: The boundary condition can only have one value
Old   February 4, 2014, 12:51
Default Parser Error for driver PatchValueExpressionDriver at "1.85" :"syntax error, unexpect
  #11
Thamali
Thamali is on a distinguished road
Dear all,
I am new to swak4Foam and I am trying to develop a boundary condition to make a fixed temperature using temperature gradient.Real application is to find out the temperature using radiative heat as a heat flux at the boundary.
so
lambda*epsilon*grad(ts) =radiative heat(which requires (Tenv^4-Tboundary^4)
So both grad and radiative heat requires Tboundary.
I am trying to implement this boundary condition using the following.
interFace
type groovyBC;
#include "commonVariables"
gradientExpression "sig*emiss*2*(pow(Tenv,4)-pow(ts,4))*pow((epsilon*effectiveThermalConductivi tyS*delta),-1)" ;
fractionExpression "1";
value uniform 298;
&(commonVariables)
variables "sig=5.67e-8;emiss=0.9;Tenv=773;Yvolat=YCOs+YCO2s+YH2s+YCH4s+ YCxHyOzs;epsilon=0.5+0.5*((0.7207-Yvolat)+(0.1457-Ychar)+(0.0426-Yash));";
But Iam getting the following error,which I cannot fix.
swak4Foam: Allocating new repository for sampledGlobalVariables
Parser Error for driver PatchValueExpressionDriver at "1.85" :"syntax error, unexpected ')', expecting '('"
Context of the error:
- From dictionary: /home/thamali/OpenFOAM/thamali-2.2.2/run/tutorials/combustion/woodchipcombustion/wood_chip_boiler6/0/ts.boundaryField.interFace
Evaluating expression "sig*emiss*2*(pow(Tenv,4)-pow(ts,4))*pow((epsilon*effectiveThermalConductivi tyS*delta),-1)"
in file lnInclude/CommonValueExpressionDriverI.H at line 1181.
FOAM exiting
I saw a similar thing in this thread ,so I choosed to write here anticipating for a reply from anyone.
Thanks in advance.
Thamali
Thamali is offline   Reply With Quote
Old   February 4, 2014, 18:39
Assistant Moderator
Bernhard Gschaider
Originally Posted by Thamali View Post
Dear all,
so
interFace
type groovyBC;
value uniform 298;
&(commonVariables)
FOAM exiting
Please don't hi-jack threads. Your question has nothing to do with parabolic inlet-conditions.
Point 2: please enclose output and code in the CODE-tag (the # above). It makes it much more readable (especially the position indicator of the error)
I guess the problem is the variable delta. The patch-parser has a function delta() (this is a discretization property of the patch) and your variable clashes with that. You'll have to rename the variable
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 5, 2014, 00:30
Thamali
oh sorry,I did not mean to.
I will tag next time.
And thank you very much for the reply.
Thamali
boundary conditions, parabolic inlet, parabolic velocity
udf parabolic velocity inlet with unsteady case Faruk Beyca FLUENT 4 June 24, 2022 10:45
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
velocity profile inlet boundary condition question Lcw FLUENT 3 August 3, 2012 05:53
Inlet velocity boundary condition in Polyflow ZHANG Xian-Ming Main CFD Forum 0 October 18, 2006 21:06
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
