Diffusion term in OpenFOAM
Old   October 4, 2013, 08:00
Default Diffusion term in OpenFOAM
Matthias Stammen
MatzeS is on a distinguished road
checking the term turbulence->divDevReff(U) I came up with the following question:
The diffusion term for incompressible flows should look somehow like this (here, I ignored the viscosity):
fvc::div(fvc::grad(U)+fvc::grad(U)().T())
And this can be transformed to this:
fvc::laplacian(U)
But when I implement that into OpenFOAM, those terms give different results. I assume it is connected to the discretization schemes, but even when I use linear for all schemes, it gives me different results.
So, what do I do wrong? What do I miss? Is it because of wall-functions or boundary conditions?
Any comment is appreciated...
Regards,
Matze
MatzeS is offline   Reply With Quote
Old   February 12, 2014, 09:23
Joachim Herb
jherb is on a distinguished road
I think this wiki page might explain what is going on here:
http://openfoamwiki.net/index.php/Bu...DevReff.28U.29
Also have a look at this thread (the difference between compressible and incompressible models goes away if the continuity equation is fulfilled after convergence of the solution):
http://www.cfd-online.com/Forums/ope...ivdevreff.html
jherb is offline   Reply With Quote
Old   February 12, 2014, 09:43
Bernhard
Bernhard is on a distinguished road
fvc::laplacian(U)
Regards,
Matze
You ignored viscosity in your derivation. The turbulent viscosity is not constant, so you can't pull it through the differential.
Bernhard is offline   Reply With Quote
Old   February 12, 2014, 09:55
Matthias Stammen
thank you for your reply, it was very helpful!
Regards,
Matze
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Numerical Diffusion in OpenFOAM srikanth_b OpenFOAM 0 September 28, 2011 04:50
Using source term in OpenFOAM user369 OpenFOAM 13 August 7, 2011 08:51
diffusion Term for add. Variable Zaktatir CFX 9 July 16, 2011 09:51
Numerical diffusion error Z.Zeng Main CFD Forum 8 October 22, 1999 09:06
