Co-rotating vortices (for aero-acoustics): problem with mesh dependence |
September 30, 2014, 06:51 |
Rep Power: 11 |
Dear forum,
I'm trying to find the acoustic field induced by a pair of co-rotating vortices. This should be a spiral pattern, like in the attachment. To test things I use Lighthill's classical analogy. Set-up The velocity and pressure fields are governed by the unsteady bernouilli equation. For this case an analytical expression for the flow field exists [1,2]: U - i*V = gamma*z / ( i * pi * (z^2 - b^2) ) with z = x + i*y and b = r0*e^(i*angularSpeed*t) where r0 is the half distance between two vortex cores = 1 meter. The flow pressure is not needed for Lighthill so I've omitted it here. I have implemented this and set the parameters as in the references (speed of sound = 1 m/s, core radius = 0.1m, rho = 1 etc). Within a distance of 0.15 m of the center of each core the velocity field is replaced by the Scully vortex core model. This prevents the velocity from becoming very large in a core's center (the case has very steep gradients) and should allow one to use a very fine grid to accurately represent the acoustic source (e.g. page 90 of [1]). Problem I observe an odd behaviour of the acoustic source term and resulting acoustic field when I refine the mesh.
For convience, I've uploaded my case here: https://www.dropbox.com/sh/5qthfm2dp...raFqAXvCa?dl=0 cvLighthill.C is the solver, which includes at each time step corotatingVortices.H to generate the flow field. Suggestions are more than welcome! Jurriaan --------------------------------------------------------------------------------------------------------------------------------------------------- [1] Phd dissertation of M. Escobar: Finite Element Simulation of Flow-Induced Noise using Lighthill’s Acoustic Analogy [2] Phd dissertation of W.J. Zhu: Aero-Acoustic Computations of Wind Turbines |
December 17, 2020, 19:06 |
Esmaeel Eftekharian
Rep Power: 10 |
Dear Jurriaan,
I know that it is a long time since you have posted this issue for modelling co-rotating vertices with OpenFOAM. I am now trying to model the same co-rotating vortices with OpenFOAM solvers. I am observing the spiral pattern, however there is some difference in the amplitude of acoustic wave of my result and that of analytic solution, regardless of the mesh size I use. I was wondering if you could solve this issue and if so could kindly give me some suggestions to resolve this issue. Thank you in advance Kind Regards Esmaeel |
aeroacoustics, co-rotating vortices |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
