custom code compilation error: library linking problem
Like Tree1Likes
  • 1 Post By dzi
Old   October 10, 2014, 05:16
Default custom code compilation error: library linking problem
nadine moussa
nadine is on a distinguished road
Hello there,
I developed a new code (porousSolidificationtheta) based on interFoam, and changed the interfaceproperties library of transportModel, so I copied transport Model and relocated in my WM_PROJECT_USER_DIR)/src/ and renamed the library as libmyinterfaceproperties and compiled it after changing th Make/files as follow:
LIB = $(FOAM_USER_LIBBIN)/libmyinterfaceProperties
the library was correctly compiled :
'/home/nadine/OpenFOAM/nadine-2.0.1/platforms/linux64GccDPOpt/lib/libmyinterfaceProperties.so' is up to date.
then in my code (porousSolidificationtheta directory I changed the make/options as follow:
EXE_INC = \
-I$(WM_PROJECT_USER_DIR)/src/transportModels/interfaceProperties/lnInclude \
EXE_LIBS = \
-L$(FOAM_USER_LIBBIN) \
-llibmyinterfaceProperties \
and compiled using wmake, but got this error message:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/nadine/OpenFOAM/nadine-2.0.1/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam201/src/transportModels -I/opt/openfoam201/src/transportModels/incompressible/lnInclude -I/opt/openfoam201/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam201/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/porousSolidificationtheta.o -L/opt/openfoam201/platforms/linux64GccDPOpt/lib \
-L/home/nadine/OpenFOAM/nadine-2.0.1/platforms/linux64GccDPOpt/lib -llibmyinterfaceProperties -ltwoPhaseInterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/nadine/OpenFOAM/nadine-2.0.1/platforms/linux64GccDPOpt/bin/porousSolidificationtheta
/usr/bin/ld: cannot find -llibmyinterfaceProperties
collect2: ld returned 1 exit status
make: *** [/home/nadine/OpenFOAM/nadine-2.0.1/platforms/linux64GccDPOpt/bin/porousSolidificationtheta] Error 1
I dont get how it doesnt find llibmyinterfaceProperties even though it s compiled correctly?!?
any ideas?!?
thank you all
nadine is offline   Reply With Quote
Old   October 10, 2014, 09:04
dzi
dzi is on a distinguished road
just a guess, but maybe the error comes because of final backslash in option file ?
regards dzi
dzi is offline   Reply With Quote
Old   October 10, 2014, 09:10
nadine moussa
Hello dzi,
I actually wrote what I changed in the options file, the whole file contains the following:
EXE_INC = \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
-I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
-ltwoPhaseInterfaceProperties \
-lincompressibleTransportModels \
-lincompressibleTurbulenceModel \
-lincompressibleRASModels \
-lincompressibleLESModels \
-lfiniteVolume
so the blackslash isnt the problem, but thank you for being intrested in my thread.
Nadine
Old   October 10, 2014, 09:33
dzi
or it is maybe because of lib naming,
what happens if you try :
-lmyinterfaceProperties \
instead of
songwukong likes this.
Old   October 10, 2014, 09:50
nadine moussa
hey dzi,
cannot believe it!!! it worked! as simple as that!
just changed the name as u suggested and it worked! I lost 2 days on this!!!
thank you
Old   October 10, 2014, 09:58
dzi
perfect
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
code compilation problem with wmake bmikuz OpenFOAM Programming & Development 2 October 17, 2012 09:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 14:34
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 10:20
