March 26, 2014, 05:39 |
negative time step, possible to set?
Tom
Rep Power: 14 |
hi there,
Do you know if it possible to introduce in OF, icoFoam algorithm in particular, a time step (adjusted or not) which is negative? I mean, can I run a simulation in OF that start from t=0 and it goes till t=tstar with tstar<0 with a deltaT<0? Thank you in advance Regards |
March 26, 2014, 11:50 |
Marco A. Turcios
Rep Power: 28 |
I don't believe you can do that with the default time classes, as there is only has increment operator:
http://foam.sourceforge.net/docs/cpp/a02579.html I'm not sure in what situation these would be useful. If you really wanted it you would have to have your own time counter and decrement it, although this would only mean that your simulation was still evolving forward in time and you've flipped your time axis. That, or you could find a flux capacitor and drive 88 mph... |
March 26, 2014, 11:57 |
#3 | |
Tom
Rep Power: 14 |
Anyway my question was bad posed. Indeed the equation I want to solve are not NS classic ones but a motification of them with the temporal term which is going to be -ddt(U)...OF icofoam solver comes to be just the skeleton of the algorithm... How can I create "my own time counter"? Thank you in advance to support my idea |
March 26, 2014, 12:06 |
Marco A. Turcios
Rep Power: 28 |
I don't think you would need a negative time-step to do what you want. Is ddt(U) negative because it absolutely needs to be, or just because its on the RHS of the equation you are solving (a reference to the equations you are solving would be helpful)?
March 26, 2014, 12:15 |
Tom
Rep Power: 14 |
No, it is not just a change of hand side. It is the prescription of the equation, indeed I am dealing with the Adjoint Navier Stokes equation wich prescribe this procedure...
March 27, 2014, 04:40 |
#6 | |
Tom
Rep Power: 14 |
I mean leaving the time flows as positive but introducing at the place of Dt the term -1*Dt in the CrankNicholson schemes... My question at this point could be. If it is possible, where is that OF does compute the CrankNicholson scheme, where is the exact file where it does the discretization? |
November 6, 2014, 04:36 |
Rep Power: 14 |
Dear Tom, Dear Foamers,
In my point of view, the problem here is to set the right boundary conditions in time for the adjoint NSE. To make sure, that the problem is well posed, one definitely is forced to compute the solution of ANSE backward in time. Tom, did you find a way to realize a computation in openFOAM with negative timeSteps? I tried a lot so far, but haven't find a satisfying answer yet, so even short hints might be very useful ( I hope you're still familiar with the subject posted above...). Kind regards Tom |
negative time step |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
