error when port 1.5dev to 230
Like Tree1Likes
  • 1 Post By xianqiejiao
Old   December 7, 2014, 01:49
Question error when port 1.5dev to 230
BO
xianqiejiao is on a distinguished road
Hi every,
I got a code from my friends which was in 1.5dev version. I was trying to port it to the 230 version I am using now. While I am able to fix some bugs, there are some I have now idea and need some help. Actually, some of the errors are similar. I think they are caused from the changes in thermo and turbulence classes. I have attached the codes.
error 1
ThermoModel/visThermo.C: In constructor ‘Foam::visThermo::visThermo(const Foam::fvMesh&, const volScalarField&, const volScalarField&)’:
ThermoModel/visThermo.C:57:5: error: no matching function for call to ‘Foam::basicThermo::basicThermo(const Foam::fvMesh&)’
error 2
In file included from coSigmaY.C:50:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:123:68: error: no matching function for call to ‘Foam::incompressibleTwoPhaseMixture::incompressibleTwoPhaseMixture(Foam::volVectorField&, Foam::surfaceScalarField&, const char [5])’
     incompressibleTwoPhaseMixture twoPhaseProperties(U, phi, "Ybar");
error 3
/home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/IOobject.H:250:35: note:                 const Foam::objectRegistry& Foam::IOobject::db() const
TurbModel/highDensityRatioKEpsilon.C:195:7: error: no matching function for call to ‘Foam::compressible::RASModel::RASModel(const Foam::word&, const volScalarField&, const volVectorField&, const surfaceScalarField&, const Foam::basicThermo&)’
error 4
/home/bo/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/compressible/RAS/lnInclude/RASModel.H:109:9: note:   candidate expects 1 argument, 5 provided
createFields.H:245:15: error: cannot declare variable ‘thermo’ to be of abstract type ‘Foam::visThermo’
     visThermo thermo(mesh, rho, Ybar);
error 5
createFields.H:257:9: error: no matching function for call to ‘Foam::compressible::turbulenceModel::New(Foam::volScalarField&, Foam::volVectorField&, Foam::surfaceScalarField&, Foam::visThermo&)’
error 6
/home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:76:66: error: cannot allocate an object of abstract type ‘Foam::compressible::RASModels::highDensityRatioKEpsilon’
             return autoPtr< baseType >(new baseType##Type parList);           \
Any suggestion is welcome. Thanks very much.
turbobluestreak likes this.
xianqiejiao is offline   Reply With Quote
Old   December 8, 2014, 02:18
BO
Update:
With the help of google, I have fixed most of the errors. However, there is last one remain.
ThermoModel/visThermo.C: In constructor ‘Foam::visThermo::visThermo(const Foam::fvMesh&, const Foam::word&)’:
ThermoModel/visThermo.C:58:5: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField()’
ThermoModel/visThermo.C:58:5: note: candidates are:
In file included from /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricField.H:601:0,
                 from /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/volFields.H:37,
                 from /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/thermophysicalModels/basic/lnInclude/basicThermo.H:38,
                 from ThermoModel/visThermo.H:38,
                 from ThermoModel/visThermo.C:26:
I tried to make the visThermo looks like psiThermo, but it seem not working...
Any suggestion on this ? Many thanks .
Old   December 8, 2014, 03:01
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You've got volScalarField mu_ in class definition but for some reason you've omitted its initialization from visThermo constructor (so compiler tries default constructor with no arguments but there's no such constructor of volScalarField).
alexeym is offline   Reply With Quote
Old   December 8, 2014, 04:25
Smile
BO
Originally Posted by alexeym View Post
Thank you for the tips, I forgot the instialization of mu_.
Then I fount another error I have omitted:
usr/bin/ld: cannot find -lbasicThermophysicalModels
/usr/bin/ld: cannot find -llduSolvers
collect2: error: ld returned 1 exit status
make: *** [/home/bo/OpenFOAM/bo-2.3.0/platforms/linux64GccDPOpt/bin/halfcoSigmaY] Error 1
as I can't find any of these two libs in other solvers, I assume they are version errors. I changed the basicThermophysicalModels to fluidThermophysicalModels and deleted the llduSolvers. I hope this should be fine.
However, after I did this, following error happens:
createFields.H:265:9: error: no matching function for call to ‘Foam::compressible::turbulenceModel::New(Foam::volScalarField&, Foam::volVectorField&, Foam::surfaceScalarField&, Foam::visThermo&)’
createFields.H:265:9: note: candidate is:
In file included from coSigmaY.C:36:0:
/home/bo/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/compressible/turbulenceModel/lnInclude/turbulenceModel.H:144:41: note: static Foam::autoPtr<Foam::compressible::turbulenceModel> Foam::compressible::turbulenceModel::New(const volScalarField&, const volVectorField&, const surfaceScalarField&, const Foam::fluidThermo&, const Foam::word&)
         static autoPtr<turbulenceModel> New
/home/bo/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/compressible/turbulenceModel/lnInclude/turbulenceModel.H:144:41: note:   no known conversion for argument 4 from ‘Foam::visThermo’ to ‘const Foam::fluidThermo&’
It seems to arise from visThermo I used. How should I solve this error now? I used the same way to creat turbulence model in sonicFoam, which uses psiThermo.
Info << "Creating turbulence model\n" << endl;
    autoPtr<compressible::turbulenceModel> turbulence
            rho,
            U,
            phi,
            thermo
Old   December 8, 2014, 04:36
Alexey Matveichev
Here's excerpts from different files that will illustrate final conclusion:
psiThermo.H
class psiThermo
    public fluidThermo
compressible/turbulenceModel/turbulenceModel.H
        //- Construct from components
        turbulenceModel
            const volScalarField& rho,
            const volVectorField& U,
            const surfaceScalarField& phi,
            const fluidThermo& thermoPhysicalModel,
            const word& turbulenceModelName = typeName
visThermo.H
class visThermo : public basicThermo
I.e. turbulenceModel constructor expects fluidThermo, while you give it basicThermo.
Old   December 8, 2014, 06:54
BO
Ah, I forgot to correct this! It seems that there is no fluidThermo class in the early versions. I change the parent class from basicThermo to fluidThermo and it works.
Then more reference problems show up...... :
Make/linux64GccDPOpt/coSigmaY.o: In function `main':
coSigmaY.C:(.text.startup+0x19b8): undefined reference to `Foam::incompressibleTwoPhaseMixture::incompressibleTwoPhaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::word const&)'
Make/linux64GccDPOpt/visThermo.o: In function `Foam::visThermo::type() const':
visThermo.C:(.text._ZNK4Foam9visThermo4typeEv[_ZNK4Foam9visThermo4typeEv]+0x3): undefined reference to `Foam::visThermo::typeName'
Make/linux64GccDPOpt/visThermo.o: In function `Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>::iterator Foam::basicThermo::lookupThermo<Foam::visThermo, Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash> >(Foam::dictionary const&, Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>*)':
visThermo.C:(.text._ZN4Foam11basicThermo12lookupThermoINS_9visThermoENS_9HashTableIPFNS_7autoPtrIS2_EERKNS_6fvMeshERKNS_4wordEES9_NS_6string4hashEEEEENT0_8iteratorERKNS_10dictionaryEPSH_[_ZN4Foam11basicThermo12lookupThermoINS_9visThermoENS_9HashTableIPFNS_7autoPtrIS2_EERKNS_6fvMeshERKNS_4wordEES9_NS_6string4hashEEEEENT0_8iteratorERKNS_10dictionaryEPSH_]+0x873): undefined reference to `Foam::visThermo::typeName'
visThermo.C:(.text._ZN4Foam11basicThermo12lookupThermoINS_9visThermoENS_9HashTableIPFNS_7autoPtrIS2_EERKNS_6fvMeshERKNS_4wordEES9_NS_6string4hashEEEEENT0_8iteratorERKNS_10dictionaryEPSH_[_ZN4Foam11basicThermo12lookupThermoINS_9visThermoENS_9HashTableIPFNS_7autoPtrIS2_EERKNS_6fvMeshERKNS_4wordEES9_NS_6string4hashEEEEENT0_8iteratorERKNS_10dictionaryEPSH_]+0xb6e): undefined reference to `Foam::visThermo::typeName'
Make/linux64GccDPOpt/visThermo.o: In function `Foam::autoPtr<Foam::visThermo> Foam::basicThermo::New<Foam::visThermo>(Foam::fvMesh const&, Foam::word const&)':
visThermo.C:(.text._ZN4Foam11basicThermo3NewINS_9visThermoEEENS_7autoPtrIT_EERKNS_6fvMeshERKNS_4wordE[_ZN4Foam11basicThermo3NewINS_9visThermoEEENS_7autoPtrIT_EERKNS_6fvMeshERKNS_4wordE]+0x14a): undefined reference to `Foam::visThermo::fvMeshConstructorTablePtr_'
Make/linux64GccDPOpt/highDensityRatioKEpsilon.o: In function `Foam::compressible::RASModels::highDensityRatioKEpsilon::type() const':
highDensityRatioKEpsilon.C:(.text._ZNK4Foam12compressible9RASModels24highDensityRatioKEpsilon4typeEv[_ZNK4Foam12compressible9RASModels24highDensityRatioKEpsilon4typeEv]+0x3): undefined reference to `Foam::compressible::RASModels::highDensityRatioKEpsilon::typeName'
Is this the error from my option file? But I checked it, it seems to be alright to me.
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/thermophysicalFunctions/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/laminarFlameSpeed/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/compressible/LES/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/compressible/RAS/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lincompressibleTransportModels \
    -lcompressibleRASModels \
    -lcompressibleLESModels \
    -lfluidThermophysicalModels \
    -lthermophysicalFunctions \
    -lspecie \
    -lchemistryModel \
    -lcompressibleTurbulenceModel
Old   December 8, 2014, 07:59
Alexey Matveichev
First, you need to change
    //- Runtime type information
    TypeName("psiThermo");
into
    TypeName("visThermo");
in visThermo.H.
Then you need to add block similar to:
namespace Foam
    defineTypeNameAndDebug(visThermo, 0);
    defineRunTimeSelectionTable(visThermo, fvMesh);
in visThermo.C.
See psiThermo implementation in 2.3.x.
Also you need to do the same operation with highDensityRatioKEpsilon class.
Old   December 8, 2014, 09:08
BO
Thank you for the tips. I have checked visThermo again and compared it to the psiThermo, tried to make them with exactly same structures. Attachments are the updated version.
However, when I finished this, suddenly everything became undeclared...just to name a few in the following:
ThermoModel/visThermo.C:90:8: error: ‘visThermo’ has not been declared
   void visThermo::setT(const volScalarField& temp)
ThermoModel/visThermo.C:90:30: error: ‘volScalarField’ does not name a type
ThermoModel/visThermo.C:90:46: error: ISO C++ forbids declaration of ‘temp’ with no type [-fpermissive]
ThermoModel/visThermo.C: In function ‘void setT(const int&)’:
ThermoModel/visThermo.C:92:5: error: ‘T_’ was not declared in this scope
     T_ = temp;
ThermoModel/visThermo.C: At global scope:
ThermoModel/visThermo.C:95:8: error: ‘visThermo’ has not been declared
   void visThermo::update(const volScalarField& rho,const volScalarField& Ybar)
ThermoModel/visThermo.C:95:32: error: ‘volScalarField’ does not name a type
ThermoModel/visThermo.C:95:48: error: ISO C++ forbids declaration of ‘rho’ with no type [-fpermissive]
ThermoModel/visThermo.C:95:58: error: ‘volScalarField’ does not name a type
ThermoModel/visThermo.C:95:74: error: ISO C++ forbids declaration of ‘Ybar’ with no type [-fpermissive]
And I also notice there are some fancy error like this:
Old   December 8, 2014, 09:37
Alexey Matveichev
there's no visThermo class outsize Foam namespace (also there's no volScalarField class outside Foam namespace ).
So all your
void visThermo::...
should be
void Foam::visThermo::...
Old   December 8, 2014, 22:04
BO WANG
wang219910611 is on a distinguished road
Hi, thanks very much for the tips. I guess I should go over c++ again before I start my next code.
Anyway, problem solved except this one
I guess this is my lib problem, here is my option file
EXE_INC = \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lspecie \
    -lchemistryModel \
as you can see, this is not link to incompressibleTwoPhaseMixture.H file as I made small changes to it, and I put it in my coSigmaY folder. Here is the change:
            const word& alpha1Name = "alpha1"
I added the last line so I can do this in my creatField.H file:
Can I solve this without interrupt my original src file?
wang219910611 is offline   Reply With Quote
Old   December 9, 2014, 02:25
Alexey Matveichev
It's rather strange as the constructor for incompressibleTwoPhaseMixture is in libincompressibleTransportModels, and this library is included in your options.
I'm afraid you've again redefined something somewhere and would like others to guess your modifications of the code. And I think this is the case as compiler gladly passes your constructor (which is redefined in your H file) while linker rejects it because it is not implemented.
Old   December 12, 2014, 01:48
BO WANG
Hi alexeym,
I turned back to the code this morning. And I think I have managed to fixed it. I linked the code to the original incompressbleTwoPhaseMixture src file and changed its announcement in the creatField.H file accordingly( rather then change the incompressibleTwoPhaseMixture file itself!). Then everything goes well.
Thanks again for your patience and all the advice.
Regards
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
Understanding Port Flow Results Ospi FLUENT 0 July 15, 2013 23:11
IC Engine Exhaust Port Flow Ospi ANSYS 1 July 10, 2013 22:59
IC Engine Exaust Port Flow Ospi FLUENT 0 July 6, 2013 20:34
OpenFOAM Cygwin port updated to 13 brooksmoses OpenFOAM Installation 29 November 30, 2006 05:49
