Multi-Dimensional Array - 4th order
Like Tree2Likes
  • 1 Post By Tobi
  • 1 Post By marupio
Old   February 8, 2015, 14:10
Default Multi-Dimensional Array - 4th order
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I think it is a very stupid question but how can I build a 4th order array in FOAM?
T[w][x][y][z]
like:
vector< vector< vector< vector<double> > > > T
Thanks in advance,
t.oliveira likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 10, 2015, 10:39
David Gaden
marupio is on a distinguished road
What do you want to do with the data? There's a number of OpenFOAM-ish ways to do that, each with different advantages.
In OpenFOAM, "List" is (very close to) a std::vector.
List<List<List<scalarList> > > T();
or with math operators
List<List<scalarFieldField> > T();
You could also use PtrList, or UPtrList if unallocated.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   February 10, 2015, 10:53
Tobi's Avatar
Tobias Holzmann
thanks for your replay. I store thermodynamic values in that array. Maybe you know the flamelet model? There you have all thermodynamic values based on three variables - with defect you have four variables. Therefore I have to store it in an very big array.
Like
phi of enthalpy, dissipation rate, mixture fraction and varianz mixture fraction
\phi = f(h,\chi,Z,Z'')
Hence this I need a 4d array:
T[h][chi][Z][Zvar]
Hope its clearer.
I only have to read a file, store the date in the array and then extract the data again (no mathematical operations are needed within this array).
So do you think, list is a good choice ?
Thanks in adavance,
Keep foaming,
Tobias Holzmann
Old   January 20, 2021, 11:00
Default converting 3D array to a 4D array
Prabhu Kankatala
Prabs27 is on a distinguished road
Hi @Tobi , this thread seems to be a decade old but i hope you still remember what you were talking about and hope you figured out. You seem to have some experience in working with multi-dimensional arrays in openFoam. I have to convert a 3 dimensional array into 4 dimensional one in a humongous code. For eg:
lift[i][j][k]=0.5*Cl[i][j][k]*Vmag[i][j][k]*Vmag[i][j][k]*chord*db[i][k];
can you suggest any sources where i can learn to add an index say l to make it like [i][j][k][l] throughout my code consistently.
Regards
Prabs
Prabs27 is offline   Reply With Quote
Old   January 20, 2021, 11:29
Tobi's Avatar
Tobias Holzmann
You can use the <map> container and use keys. http://www.cplusplus.com/reference/map/map/
Keep foaming,
Tobias Holzmann
Runge Kutta 4th Order Source Code sugu Main CFD Forum 4 October 26, 2012 03:15
4th and 5th Order TVD Runge-Kutta Methods saygin Main CFD Forum 2 January 30, 2006 11:45
Help on fortran code for FD 4th order Miguel Main CFD Forum 0 November 14, 2005 10:58
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 16:31
Neighboring cells in TETRA_4 unstructured grids Amaresh Dalal Main CFD Forum 12 September 19, 2004 11:54
