Reading values from file
Old   February 9, 2015, 12:43
Default Reading values from file
Tobi's Avatar
Tobias Holzmann
I want to read a file with FOAM classes. I checked out the boundary condition "timeVaryingMappedFixedValue" but I did not get the point how to read a file and store the values in an array (scalarField etc.)
At the moment I created an IFstream:
const fileName pathToFile = "foobar";
IFstream foo(pathToFile);
But now I do not know how to read that file.
Thanks in advance
Tobi
Keep foaming,
Tobias Holzmann
Old   February 9, 2015, 15:43
anonymous
ssss is on a distinguished road
Dear Tobi,
As I can see in the openfoam code (IFstream.H - .C) there are practically no implemented functions for the IFstream class.
Why don't you use the original ifstream C++ class? You can read everything with it.
ssss is offline   Reply With Quote
Old   February 9, 2015, 16:53
Tobi's Avatar
Tobias Holzmann
Because I wanna use FOAM classes
But yes as you told, it seems to be no implementation of functions for that file but it sdhould be possible to do sth. like that.
Keep foaming,
Tobias Holzmann
Old   February 10, 2015, 03:02
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Can you please clarify several moments:
1. You'd like to read values into array (i.e. just a sequence of values) or it should be a Field (i.e. values have spatial variations and linked to the mesh)?
2. You'd like to read ASCII file, binary file?
3. What is wrong with ISstream's read method? http://foam.sourceforge.net/docs/cpp...e693cadb1d0305
4. If I am not mistaken there are also overloaded right shift operators.
4. Finally there is DataEntry class which can read values from OpenFOAM's dictionaries/CSV files. Though in this case it's more complicated as the class adds interpolation.
alexeym is offline   Reply With Quote
Old   February 10, 2015, 03:20
Tobi's Avatar
Tobias Holzmann
Hi Alex,
thanks for your reply. Did not know why I am not using ISstream. Yesterday I had a look at Doxygen and got the point that ISstream would be a good class (necessary functions available like getLine() ...).
I will test it today in the evening. At least to your questions:
  • The values are like a list of different scalars like:
#List which has to be read
1e4
1e2
0
-1e2
-1e5
-3e5
  • This file is read in ascii format but I also has to read binary files
Thanks in advance,
Keep foaming,
Tobias Holzmann
Old   February 10, 2015, 04:03
Alexey Matveichev
Originally Posted by Tobi View Post
thanks for your replay. Did not know why I am not using ISstream. Yesterday I had a look to Doxygen and get the point that ISstream would be a good class (necessary functions available like getLine() ...).
IFstream is a child of ISstream (see inheritance diagram: http://foam.sourceforge.net/docs/cpp/a01016.html), so public method of ISstream are available in IFstream.
In case of ASCII files solution if straightforward, read line, if it is not a comment try to parse number.
In case of binary files everything is a little bit more complicated. Read into char buffer, convert into scalar. Though I'm not quite sure that is not an invention of the wheel.
About timeVaryingMappedFixedValue, list is read during construction of this property of the class:
autoPtr<DataEntry<Type> > offset_;
and then it is used in the code like this
offset_->value(t)
but as I said earlier DataEntry assumes value pairs (time, value).
Old   February 10, 2015, 04:37
Tobi's Avatar
Tobias Holzmann
Thank you again.
Well I am stupid because I checked the Doxygen and saw that IFstream is a child of ISstream but in the header I checked the wrong class which has no derivation to ISstream. After your hints I checked it again and now I get the lines:
   82 class IFstream    83 :
    84     public IFstreamAllocator,
    85     public ISstream
    86 {
So then it should be possible to use IFstream and use the ISstream functionallity. I try it today in the evening.
Keep foaming,
Tobias Holzmann
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
