Source Term in chtMultiRegionFoam
Like Tree3Likes
  • 3 Post By ssss
Old   April 16, 2015, 15:21
Default Source Term in chtMultiRegionFoam
N/A
kamakura117 is on a distinguished road
I am beginning the development of another solver, but I'm pretty amateur at C++. The solver I am writing requires a bit more detailed source term than is possible, currently, with fvOption. In this effect, I am just beginning my baby steps. I have scoured the forum for an avenue forward, but I'm having some problems.
I am starting with OpenFoam 2.3.1.
So, simply speaking, I create a new scalar field in createSolidFields.H:
PtrList<volScalarField> q(solidRegions.size());
forAll(solidRegions, i)
        Info<< "    Add  source\n" << endl;
        q.set
            i,
            new volScalarField
                IOobject
                    "q",
                    runTime.timeName(),
                    solidRegions[i],
                    IOobject::MUST_READ,
                    IOobject::NO_WRITE
                solidRegions[i]
Then I suspect, I could simply add this in solveSolid.H:
            fvOptions(rho, h)
            + q
But, I am returned with an exceptionally long compilation error, which looks to be associated with a miss-match in matrix/scalar notion for the solver. However, as defined, the "q" source term is a matrix and the solver loop beings with "tmp<fvScalarMatrix> hEqn" So, I am a bit confused.
Any guidance would be appreciated.
kamakura117 is offline   Reply With Quote
Old   April 19, 2015, 03:58
anonymous
ssss is on a distinguished road
Are you sure that the dimensions of q are right?, maybe you should use fvc::div(q).
ssss is offline   Reply With Quote
Old   April 19, 2015, 11:53
N/A
Thanks for the response.
The dimensions of "q" are J/kg. It should be a scalar value. I don't think that a divergence makes sense here, or am I misinterpreting the result of the operation?
Old   April 20, 2015, 13:35
anonymous
So if q is a scalar value, then you shouldn't be reading it as an IOobject, you should read it from as a dimensioned scalar from the transportProperties and then create a volScalarField from it if you want.
I meant that q must have the correct dimensions, as I see you are introducing the source term in the energy equation and thus it must have [J]/([m^3][s]) dimensions if I've done the operations correctly.
Old   April 20, 2015, 14:46
N/A
I need to multiply by the density; however, I am just taking the source term one step at a time. Currently, I can't compile, so implicitly the dimensions don't matter too much until it reads in the initial conditions.
The IOobject is necessary. The computation of "q" will be done with an external code and I want it to be read from a file where I am writing a dictionary for all of the volumes. For each volume, it is a scalar, it is not a vector.
For completeness, the compilation error that I receive is a lot of something like:
/solid/solveSolid.H:17:26: note:   cannot convert ‘q’ (type ‘Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’) to type ‘const Foam::zero&’
             ) - q
and
./solid/solveSolid.H:17:26: note:   cannot convert ‘q’ (type ‘Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’) to type ‘const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&’
             ) - q
Thanks.
Old   April 20, 2015, 15:18
anonymous
I think I might have an answer for your errors. Open the setRegionSolidFields.H file and add this line:
 const volScalarField& qRegionI = q[i];
Then modify the hEqn in the solveSolid.H file:
            fvm::ddt(betav*rho, h)
               thermo.isotropic()
             ? fvm::laplacian(betav*thermo.alpha(), h, "laplacian(alpha,h)")
             : fvm::laplacian(betav*taniAlpha(), h, "laplacian(alpha,h)")
            fvOptions(rho, h)
            +qRegionI
The problem relies in the fact that you are creating an array of q objects, one for each of the solidRegions, so when you discreteza the hEqn, you must select the element of q which relies in the region you are solving. Hope it helps.
kamakura117, stingph and zhuangli like this.
Old   April 21, 2015, 18:50
N/A
Excellent! I didn't even notice that header file, and that's exactly what was happening.
Cheers.
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
