.stl from calculated quad-points
Old   August 7, 2015, 05:18
Default .stl from calculated quad-points
Phil_ is on a distinguished road
Dear Foamers,
is there an easy way to create an .stl-file from calculated points in the domain?
The calculated points describe quadFaces, so I tried splitting them with the triangles() function from the face-class (src/OpenFOAM/meshes/meshShapes/face/face.C). This function expects a pointField as an argument.
How can such a pointField be defined by the calculated quad points? Is it necessary to create a whole new mesh-instance?
Kind regards
Philip
Phil_ is offline   Reply With Quote
Old   August 7, 2015, 06:52
Just found out how points can be added to the pointField. It's only possible component wise:
vector pTest = vector(1.0, 2.0, 3.0);
// points[0][0] = pTest; //does not work
points[0].x() = pTest.x();
points[0].y() = pTest.y();
points[0].z() = pTest.z();
[snappyHexMesh] SnappyHexMesh .stl Jochem OpenFOAM Meshing & Mesh Conversion 10 September 23, 2016 04:26
Extract points from polyline Saidul ANSYS 0 January 18, 2015 21:54
Projecting Points onto .stl Defined Surface mchurchf OpenFOAM 3 August 17, 2012 17:19
How to import only some points in paraFoam? maximeg OpenFOAM Running, Solving & CFD 1 July 12, 2010 10:56
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
