June 24, 2018, 14:19 |
solid cylinder motion
Ben 017
Rep Power: 8 |
Hope you are well! May you help on this case? Indeed i want to move a solid cylinder, I have coded in c++ the equation of motion(simple harmonic equation). The cylinder was created using cylinderTocell in topoSetDict. Can you help to know how make that cylinder oscillating using that equation. or if you know another way to use to make that cylinder oscillating without dynamic mesh, i will be happy to hear from you. Attached is the c++ equation of motion. Regard! Thank you. |
June 24, 2018, 17:15 |
Michael Alletto
Rep Power: 15 |
first of all you do not need any ode solver for a harmonic oscillation. There exists an analytical solution. I think there is no other option than to use the dynamicMesh in OpenFoam to model displacement. There exist an arbitrary mesh interface where two mesh can be moved along a common interface. |
dynamicFvMesh - tabulated motion of a solid body + mesh morphing | HendrikW | OpenFOAM Pre-Processing | 3 | December 3, 2019 02:05 |
FSI with motion of solid parts: Any tips? | maccheese | Fluent Multiphase | 0 | March 6, 2018 09:02 |
Motion trajectories of an oscillating cylinder | Thaw Tar | OpenFOAM Post-Processing | 0 | April 14, 2015 08:42 |
Solid motion | Martin_Sz | CFX | 4 | March 20, 2015 04:51 |
Help in Meshing Solid Cylinder in Gambit. | Andy Singh | FLUENT | 5 | August 31, 2004 07:31 |
