multiRegion with change phase
Old   October 28, 2015, 10:35
Default multiRegion with change phase
Cartuns11's Avatar
Cartuns11 is on a distinguished road
Hi everybody,
I'm working on a thermal exchanger (water/air). It consists in two cylinders, one of then is inside the other. The air goes through the water cylinder via a tube. Initially, the air is 600K and the water is 300K but at the end, water gets 420K......water should evaporate but it doesn't.
I'm using chtMultiRegionSimpleFoam because my model has 2 domains (air tube, water cylinder) but it doesn't take into account the change phase.
I wonder how I can carry out a simulation with both concepts (multiRegion and change phase). Is there a solver, which can do it? or the only way, is the modify the code?
Thanks
Cartuns
Cartuns11 is offline   Reply With Quote
Old   October 28, 2015, 11:37
Cyp
Cyprien
Cyp is on a distinguished road
may be by not using a multi region solver but a VOF approach? At least this is what you'll learn if you do a literature review.
Cyp is offline   Reply With Quote
Old   January 10, 2016, 13:27
Peng Liang
tjliang is on a distinguished road
Originally Posted by Cartuns11 View Post
Hi everybody,
Thanks
Cartuns
I am also looking for a good solver dealing with multi-region problems and phase change effect. Have you found out one solver or any good idea?
Thanks ,
Peng
tjliang is offline   Reply With Quote
Old   January 10, 2016, 15:37
Smile
Hesam
rapierrz is on a distinguished road
I wrote a solver with temperature base phase change and then combine it
with conjugateHeatFoam solver that wroten by Hrvje Jasak,I validate phase
change section of this solver But I don't know it's conjugate section work
correctly or not!
rapierrz is offline   Reply With Quote
Old   June 24, 2018, 07:47
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by rapierrz View Post
correctly or not!
Any updates on this issue?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
heat, multiregion, phase change
homogeneous free surface flow with phase change. Niru CFX 13 December 26, 2013 10:27
Pressure Outlet for phase change simulation dinesh FLUENT 0 November 21, 2013 23:50
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 03:59
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 06:27
