New Phase Compressible Turbulence Model for multiphase system
Old   November 24, 2015, 00:17
Default New Phase Compressible Turbulence Model for multiphase system
Vishal
vishal3 is on a distinguished road
Hi all,
I am trying to compile new phase compressible turbulence model for multiphase system. I am using OpenFOAM-2.3.1. The details of the model are as follows:
In openFOAM-2.3.1/src/TurbulenceModels/phaseCompressible/RAS, there is a mixtureKEpsilon model. This model solves turbulence for gas-liquid mixture and then by using that mixture k and epsilon, k and epsilon are calculated for individual phases, that is, gas and liquid. By solving this model, you get final k and epsilon (which constitute of accumulation, convection, production, viscous and turbulent transports of k and epsilon). In my case, I want to calculate these individual terms (accumulation, convection, production, viscous and turbulent transports) in k and epsilon. So I have modified same files for mixtureKEspilon model in order to calculate all the individual terms and saved it as mymixtureKEpsilon.C and mymixtureKEpsilon.H files.Now, I put these files in openFOAM-2.3.1/src/TurbulenceModels/phaseCompressible/RAS/mymixtureKEpsilon.
My problem is that I am not able to compile it now. Please somebody tell me how to compile this model, so that I can use it instead of mixtureKEpsilon model. I am attaching modified .C and .H files with this.
Thanking you,
vishal3 is offline   Reply With Quote
Fluent Limitations tymcme FLUENT 6 August 1, 2022 08:50
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Turbulent frequency equation for compressible kOmegaSST turbulence model (F1) Bojan OpenFOAM Programming & Development 1 September 1, 2013 12:20
Mixture model with one compressible fluid phase oden FLUENT 0 September 26, 2006 09:11
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
