Adding porous zones to compressible multiphase solvers
Old   May 31, 2011, 05:20
Default Adding porous zones to compressible multiphase solvers
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear all,
I am new to OpenFoam. I wish to add porous zones support to compressibleInterDyMFoam. By checking code of (interFoam, porousInterFoam, interDyMFoam, compressibleInterFoam & compressibleInterDyMFoam), it seems that I just have to include both the porousZones.H and createPorousZones.H headers to add porous zones support to the compressibleInterFoam or compressibleInterDyMFoam. Is this enough? Or should there be any other issues that I should attend to?
Best regards,
Hisham El Safti
Hisham is offline   Reply With Quote
Old   June 1, 2011, 03:22
Cecily
Black-Pearl is on a distinguished road
I have such a question, too. I wish to add a porous zone support to MRFSimpleFoam. Is it possible?
Have you check your calculation?
Black-Pearl is offline   Reply With Quote
Old   June 1, 2011, 03:42
Hisham's Avatar
Hisham Elsafti
I have not done it yet, but I plan to. When I do, I'll post the results. Of course it would be better if I would know if more work is to be anticipated than just including headers!
Old   June 7, 2011, 08:17
Cecily
Do you know how to combine two solvers together?
Old   August 23, 2011, 03:25
Manoj L Das
run_cfd is on a distinguished road
Hi Hisham,
Did you succeeded in combining the two solvers? If yes, then could you share your brief method in doing so.
Thanks,
Manoj
run_cfd is offline   Reply With Quote
Old   August 25, 2011, 09:27
Hisham's Avatar
Hisham Elsafti
Hello Manjo
I did not have time to do that just yet.
But I'm quite sure, now, that it is that straight forward (I think )
I may try to do it soon. I just got involved in other stuff
Old   March 17, 2014, 09:20
Fran
lfbarcelo is on a distinguished road
I know this is an old post but answering may help others.
You should also add the corresponding term to the momentum equation (UEqn). "pZones.ddt(rho, U)" on the left side.
This works on versions up to 2.1.
I think that 2.2 has a different way of treating porousZones.
lfbarcelo is offline   Reply With Quote
Old   November 27, 2015, 02:55
brocco is on a distinguished road
hi marcelo, i tried with your suggestion but without succes unfortunately! I've tried to add in the Ueq both the term you suggested and, in a second time the term "pZones.addResistance(UEqn);" after Urelax (as is done in interporousfoam and in rhoPorousetc).
Have you other suggestions?actually the problem seems to fall in the create fields. I receive an error :
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
dimensions : [1 -3 0 0 0 0 0] + [0 0 0 0 0 0 0]
when the line:
volScalarField rho1("rho1", eos1->rho(p, T));
is reached.
I know that the post is very old but....
brocco is offline   Reply With Quote
Old   November 27, 2015, 05:14
Obviously....if someone else had good experiences with porous zones via fvOptions in more recent versions of compressibleInterFoam or twoPhaseEulerFoam is welcome!
thnx in advance to evrbdy
compressibleinterdymfoam, dynamic mesh, multiphase, porous
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Multiphase flow & porous media Hisham OpenFOAM 3 April 10, 2011 07:04
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 04:50
Help:What's wrong with my porous zones setting!!? jjw FLUENT 2 August 26, 2005 05:16
Inputs for porous zones in FLUENT Roel van Os Main CFD Forum 1 September 1, 1998 12:41
