chtMultiRegionFoam - solid diffusion number dimension |
April 20, 2016, 17:00 |
Florian
Hello
in OpenFOAM-3.0.1/applications/solvers/heatTransfer/chtMultiRegionFoam/solid/solidRegionDiffNo.C the calculation of the solid diffusion number is given, which is basically: DiNum = alpha * deltaT * deltaCoeffs() with the thermal diffusivity alpha=kappa/rho/cp. If DiNum should be dimensionless, deltaCoeffs() should have the dimension 1/m^2. The calculation of deltaCoeffs() is given in: OpenFOAM-3.0.1/src/finiteVolume/interpolation/surfaceInterpolation/surfaceInterpolation/surfaceInterpolation.C and discussed in http://www.cfd-online.com/Forums/ope...ltacoeffs.html From that I expect the dimensions of deltaCoeffs() to be 1/m, so that an additional 1/m is missing somewhere (if DiNum is expected to be dimensionless). I would really appreciate if someone could shed light on this issue. Best regards Florian |
January 23, 2023, 15:43 |
Mostafa
Rep Power: 9 |
It's been so many years but I'm having the same question Have you found an answer?
Also, I'm under the impression that delfaCeoffs() is dimensionless; referring to basicFvGeometryScheme.C, line 156: "Constructing differencing factors array for face gradient". The calculation of DiffNo is given as surfaceScalarField kapparhoCpbyDelta ( sqr(mesh.surfaceInterpolation::deltaCoeffs()) *fvc::interpolate(kappa) /fvc::interpolate(Cprho) ); const scalar DiNum = max(kapparhoCpbyDelta).value()*runTime.deltaTValue (); So what is the square root of deltaCoeffs() ? |
September 24, 2023, 09:58 |
Rep Power: 3 |
As I know, in OpenFOAM, sqr(x) == x^2. So the dimension is correct.
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
