Stoping criterion
Like Tree1Likes
  • 1 Post By Jerryfan
Old   July 24, 2016, 11:49
Default Stoping criterion
anonymous
cute is on a distinguished road
Hi All,
I want to stop my simulation when C < tolerance_Value or C < 0 at any grid point. I don't know, how to write the condition in while loop? I need your help, code is given below.
while (????)
         Info<< "Time = " << runTime.timeName() << nl << endl;
         forAll(CX, cellI)
                   CX[cellI] = alpha.value()*C[cellI]*C[cellI];
         solve(fvm::ddt(C) == fvm::laplacian(DT, C) - k*CX*C);
         runTime.write();
cute is offline   Reply With Quote
Old   July 25, 2016, 11:35
Mahdi Hosseinali
anishtain4 is on a distinguished road
You can use panicDump during the run rather than putting it in the solver.
anishtain4 is offline   Reply With Quote
Old   July 25, 2016, 15:10
Jerry
Jerryfan is on a distinguished road
Hi cute,
You can simply add a line that gives the maximum of C, and then determine based on this maximum value.
while (maxC > tolerance_value)
forAll(CX, cellI)
dimensioned<Type> maxC = max(C); //Type depends on the Type of variable in field C.
runTime.write();
LogiDF likes this.
Jerryfan is offline   Reply With Quote
Old   July 25, 2016, 20:30
anonymous
Thanks for the input.
I defined C as volScalarField, is my Type equals volScalarField?
dimensioned<volScalarField> maxC = max(C);
But all the values in C are floating point numbers, I am confused what to write?
Old   July 25, 2016, 20:34
Jerry
What I mean is Type of variable in field C, not the Type of field C itself. In this case, you should use
dimensioned<scalar>
Old   July 25, 2016, 20:35
anonymous
Thanks for a quick response.
Old   July 31, 2016, 12:26
anonymous
I am using the following code as suggested, but I am getting error:
CODE:
dimensioned<scalar> maxC = max(C);
dimensioned<scalar> minC = min(C);
    while (maxC > 1E-6 && minC > 0.0)
ERROR:
 error: no match for ‘operator>’ (operand types are ‘Foam::dimensioned<double>’ and ‘double’)
Old   July 31, 2016, 12:52
Jerry
CODE:
ERROR:
You can try to get the value out from the dimensionedType variable by:
while (maxC.value() > 1E-6 && minC.value() > 0.0)
Old   July 31, 2016, 14:27
anonymous
Thanks, it works.
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Is convergence criterion (residual value) related with grid size? rdeepakkumar FLUENT 2 November 9, 2014 01:19
Asymptotic stopping criterion is not working rob50904 STAR-CCM+ 2 January 28, 2013 08:25
question to courant criterion tH3f0rC3 OpenFOAM 6 May 16, 2011 04:32
convergence criterion Dominique FLUENT 5 November 24, 2006 02:36
