Faked mesh for internal program use
Like Tree1Likes
  • 1 Post By wouter
Old   February 1, 2017, 15:47
Default Faked mesh for internal program use
knuckles is on a distinguished road
Background: there is a function I'm interested in reusing which takes the form
 tmp<volScalarField> foo(const volScalarField& arg);
...where the implementation sets each entry in the result based on the corresponding entry in arg only. I would like to apply this same operation to a single value but don't want to re-code foo. If I could create a fake internal mesh with exactly one entry, then I could pass this mesh to the volScalarField constructor and create a volScalarField with exactly one entry, which I could pass too foo. I could then extract the result I'm interested in from the single-valued result.
Is this possible? Is there another workaround?
knuckles is offline   Reply With Quote
Old   February 2, 2017, 01:52
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I really do not get the point you want to do? Why you want to build a volScalarField with a single entry. Do it with a dimensionedScalar or just a scalar. Provide more information and you will see that we can help you. With the lack of information, it is not really understandable; especially for people who are not sitting in front of your computer and are not related to the things you do.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 2, 2017, 14:55
Wouter van der Meer
wouter is on a distinguished road
hello knuckles,
I totaly agree with Tobi, I have no clue what you want. But what I think is that you need to take a look at C++ templates, widely used in OpenFoam. This gives you the possibility to use the same function with different kind of arguments
Hope this helps,
Wouter
Tobi likes this.
wouter is offline   Reply With Quote
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
