Where to find what is the value of Universal gas constant used in the OpenFoam
Like Tree5Likes
  • 1 Post By AshwaniAssam
  • 2 Post By Tobi
  • 2 Post By AshwaniAssam
Old   October 8, 2019, 13:16
Default Where to find what is the value of Universal gas constant used in the OpenFoam
Ashwani
AshwaniAssam is on a distinguished road
Hi all,
In the file thermodynamicConstants.C the definition of universal gas constant is defined as
      // Note: the 1e3 converts from /mol to /kmol for consistency with the
     // SI choice of kg rather than g for mass.
     // This is not appropriate for USCS and will be changed to an entry in
     // the DimensionedConstants dictionary in etc/controlDict
     const scalar RR = 1e3*physicoChemical::R.value();
What I understand is the universal gas constant is denoted by R.value(). Where is this defined I am unable to locate.
I am trying to ascertain what is the gas constant value used by the perfect gas model. I want to use the gas constant value as 1.
cjacob likes this.
AshwaniAssam is offline   Reply With Quote
Old   October 8, 2019, 15:00
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
you can use Doxygen for that:
https://cpp.openfoam.org/v7/physicoC...8C_source.html
jiejie and lpz456 like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 9, 2019, 00:30
Ashwani
Thank you. I found the answer in the file you directed.
Universal gas constant = Avogadro No. * Boltzmann constant = NA * k
NA is defined in fundamentalConstants.C and k is defined dynamically in
OpenFOAM/OpenFOAM-v1906/etc/controlDict
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
error message cuteapathy CFX 14 March 20, 2012 06:45
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
