October 28, 2015, 10:35 |
multiRegion with change phase
Rep Power: 11 |
Hi everybody,
I'm working on a thermal exchanger (water/air). It consists in two cylinders, one of then is inside the other. The air goes through the water cylinder via a tube. Initially, the air is 600K and the water is 300K but at the end, water gets 420K......water should evaporate but it doesn't. I'm using chtMultiRegionSimpleFoam because my model has 2 domains (air tube, water cylinder) but it doesn't take into account the change phase. I wonder how I can carry out a simulation with both concepts (multiRegion and change phase). Is there a solver, which can do it? or the only way, is the modify the code? Thanks Cartuns |
October 28, 2015, 11:37 |
Cyprien
Rep Power: 18 |
may be by not using a multi region solver but a VOF approach? At least this is what you'll learn if you do a literature review.
January 10, 2016, 13:27 |
#3 | |
Peng Liang
Rep Power: 12 |
I am also looking for a good solver dealing with multi-region problems and phase change effect. Have you found out one solver or any good idea? Thanks , Peng |
January 10, 2016, 15:37 |
Hesam
Rep Power: 11 |
I wrote a solver with temperature base phase change and then combine it with conjugateHeatFoam solver that wroten by Hrvje Jasak,I validate phase change section of this solver But I don't know it's conjugate section work correctly or not! |
June 24, 2018, 07:47 |
Any updates on this issue?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
heat, multiregion, phase change |
homogeneous free surface flow with phase change. | Niru | CFX | 13 | December 26, 2013 10:27 |
Pressure Outlet for phase change simulation | dinesh | FLUENT | 0 | November 21, 2013 23:50 |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Two phase flow with phase change | Ahmad Al-Zoubi | CFX | 1 | November 26, 2008 03:59 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 06:27 |
