new heatTransferModell for dieselSpray lib
Old   June 25, 2010, 05:13
Default new heatTransferModel for dieselSpray lib
mystix is on a distinguished road
Hallo community,
After adding some new evaporation models like in the dieselFoam tutorial I want to add a new heat Transfer Model to the dieselSpray library.
I want to change the relaxationTime of the RanzMarshall model by adding a correction term based on Xs and Xf.
To do this I copied the RanzMarshall model and changed the equations to my needs. But I have to use some more variables: Xs and Xf for the 2nd heat transfer Model.
But I dont know how I can add these variables properly. It is not done with just adding
const scalar Xs,
const scalar Xf
const
to the relaxationTime method. Can someone help please?
Thank you in advance.
Problem was solved:
I added Xs and Xf to the relaxationTime method in all depended files which where:
heatTransferModel/RanzMarshall/RanzMarshall.C
heatTransferModel/RanzMarshall/RanzMarshall.H
heatTransferModel/heatTransferModel/heatTransferModel.H
heatTransferModel/noheatTransfer/noheatTransfer.C
heatTransferModel/noheatTransfer/noheatTransfer.H
In "parcel/setRelaxationTimes.C" I had to added the green marked commands:
for(label i=0; i<Nf; i++){
tauHeatTransfer = sDB.heatTransfer().relaxationTime(
liquidDensity, d(), liquidcL, kMixture, Reynolds, Prandtl, Xs[i], Xf[i]);}
mystix is offline   Reply With Quote
Unable to load lib file: "undefined symbol" gfilip OpenFOAM 8 May 26, 2022 07:48
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
Doubts about lib case f220 J. H. Fan Phoenics 1 June 17, 2002 02:05
3D PARALLEL SOLVER (MPI Lib) Saud Khashan Main CFD Forum 8 July 14, 1999 08:52
