Fuel Triple Points
Old   August 17, 2010, 00:38
Smile Fuel Triple Points
Arun
arun is on a distinguished road
Hi All,
I have some questions on the liquids class. Under this class if new fuel properties need to be included, these are the parameters required:
-Molecular weight [kg/kmol]
-Critical temperature [K]
-Critical pressure [Pa]
-Critical volume [m^3/mol]
-Critical compressibility factor []
-Triple point temperature [K]
-Triple point pressure [Pa]
- Normal boiling temperature [K]
- Dipole moment []
- Pitzer's accentric factor []
- Solubility parameter [(J/m^3)^0.5]
All of these values could be calculated using existing properties formula and experimental data; however, I could not find any related references for triple point temperature and pressure calculations.
Anyone know how these two values (triple point temperature and pressure) are determined in liquid class database? Which formulas of reference data were used?
In addition to that, what is the importance of these two values for other fuel properties calculations?
Thanks in advance.
Arun
arun is offline   Reply With Quote
liquids class, pressure, triple point temperature
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 03:13
burning of solid fuel lizihujx FLUENT 8 September 19, 2012 08:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
injection of fuel into tank filled with fuel mujahid FLUENT 1 February 19, 2004 06:36
