newbie question - simple pTraits
Like Tree4Likes
  • 1 Post By wyldckat
  • 3 Post By ngj
Old   April 23, 2011, 19:46
Default newbie question - simple pTraits
ans
Alan N. Sayre
ans is on a distinguished road
I want to compile the pTraits test routine using just command line e.g.
g++ pTraitsTest.C
I get:
gcc version 4.3.4 20090804 (release) 1 (GCC)
$ g++ pTraitsTest.C
pTraits.H: In instantiation of `Foam:Traits<double>':
pTraitsTest.C:42: instantiated from here
pTraits.H:52: error: base type `double' fails to be a struct or class type
pTraitsTest.C: In function `int main()':
pTraitsTest.C:42: error: `typeName' is not a member of `Foam:Traits<double>'
ansayre@ansayre2m4 /cygdrive/d/dev/OpenFOAM/OpenFOAM-1.7.1/gcc/pTraits
I defined WM_DP. What else do I need to do?
ans is offline   Reply With Quote
Old   April 24, 2011, 10:19
Retired Super Moderator
Bruno Santos
Greetings Alan,
Newbie? You're using Cygwin!
You need OpenFOAM to be already built under your development environment. If that has already been achieved, simply use this command:
wmake
It will place the binary in the folder outputted by the following command:
echo $FOAM_USER_APPBIN
It's not advisable to try and build these OpenFOAM things manually, since they have tons of dependencies!
Best regards,
Bruno
Last edited by wyldckat; April 25, 2011 at 17:48. Reason: typo: "You're" not "your"...
Old   February 5, 2014, 11:00
openfoammaofnepo is on a distinguished road
Dear Bruno,
About the pTraits, can we view them as a special scalar or vector? Because now I have met two situations they are used:
1, used in the operations:
vector omg = 2*ranGen.vector01() - pTraits<vector>::one
2, used in the initialization of some objects
loc_(pTraits<vector>::zero)
I feel that they are equal to [1 1 1] and [0 0 0]. Right?
openfoammaofnepo is offline   Reply With Quote
Old   February 5, 2014, 15:20
Bruno Santos
Hi openfoammaofnepo,
Honestly, I've got no idea what "pTraits" is. I'll have to investigate about it.
I'll try to have a look into it this coming weekend.
Best regards,
Bruno
Old   February 5, 2014, 16:53
Thank you in advance!
Old   February 9, 2014, 15:38
Bruno Santos
I did a quick search and this is what I've figured out:
  1. pTraits is located in "$FOAM_SRC/OpenFOAM/primitives/pTraits/pTraits.H"
  2. It has this comment/description:
    All primitives need a specialised version of this class. The specialised version will normally also require a conversion method.
  3. Template specialization is explained here: http://www.cplusplus.com/doc/tutoria...specialization
  4. In essence, this allows dynamic casting for whatever necessary.
  5. If you have a look into the file "$FOAM_SRC/OpenFOAM/primitives/VectorSpace/products.H", you'll see that this further extends functionality to the pTraits template class, by adding the ability to be able to handle products between 2 other items of the same pTraits template class.
Therefore, the pTraits template class is essential to how OpenFOAM handles mathematical data.
As for the question you asked:
This accesses the global definitions defined at "$FOAM_SRC/OpenFOAM/primitives/Vector/vector/vector.C".
... and I'm a bit lost in the code. I'm not 100% certain, but it either it's for accessing the static definitions of one and zero for vector, or to have access to the mathematical operators wrapped up in pTraits.
Best regards,
Bruno
shang likes this.
Old   February 9, 2014, 16:00
Thank you very much for your so detailed explanantion. I think I have more understanding after I read your reply for me.
Thank you again!
Old   February 9, 2014, 16:48
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
I will probably not be able to tell the full story, but let me share what I know:
As Bruno says, it is merely a matter of accessing ::zero, :ne, the size (e.g. number of elements) of a given type (etc).
pTraits was (allegedly) introduced in order to handle this smoothly for scalars, because they were previously derived directly from the std:: namespace, i.e. if-sentences were needed to distinguish between scalars and everything else. This caused loss of computational efficiency.
Therefore, pTraits is merely a wrapper class, which unifies access to certain properties for all primitive types.
It is used in the very core of everything, e.g. whenever you compute a gradient of a given field, the following function is called in the grad schemes:
virtual tmp
            GeometricField
            <typename outerProduct<vector, Type>::type, fvPatchField, volMesh>
        > grad
            const GeometricField<Type, fvPatchField, volMesh>&
        ) const = 0;
Here, the important part is "outerProduct", which is to be found in the file:
./primitives/VectorSpace/products.H
and the implementation reads:
template<class arg1, class arg2>
class outerProduct
public:
    typedef typename typeOfRank
        typename pTraits<arg1>::cmptType,
        int(pTraits<arg1>::rank) + int(pTraits<arg2>::rank)
    >::type type;
This is a nice example, where the pTraits is handy. The gradient operator "simply" raises the rank by one, which is achieved by this, because one of the Type-arguments in the template of the gradient operator is of type vector (rank = 1).
Kind regards,
Niels
wyldckat, shang and sencer like this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 17, 2015, 15:09
Dear ngj,
Thank you so much. Today I met the pTraits in the turbulentInlet.C again. So I had a look at thread again. The codes are as follows:
        scalar rmsCorr = sqrt(12*(2*alpha_ - sqr(alpha_)))/alpha_;
        patchField =
            (1 - alpha_)*patchField
          + alpha_*
                referenceField_
              + rmsCorr*cmptMultiply
                    randomField - 0.5*pTraits<Type>::one,
                    fluctuationScale_
                )*mag(referenceField_)
So here when patchField is vector (actually it is velocity becase it is a boundary type for velocity), is "pTraits<Type>::one" the vector [1 1 1]?
Thank you so much. OFFO
Originally Posted by ngj View Post
Good evening,
As Bruno says, it is merely a matter of accessing ::zero, ::one, the size (e.g. number of elements) of a given type (etc).
virtual tmp
            GeometricField
        > grad
        ) const = 0;
class outerProduct
public:
    >::type type;
Kind regards,
Niels
Last edited by wyldckat; August 18, 2015 at 12:03. Reason: Added [CODE][/CODE] markers
Old   August 18, 2015, 12:05
Bruno Santos
Quick answer: If the template implementation defined for "Type" is "vector", then yes, it should be the vector "(1 1 1)".
Old   August 18, 2015, 12:26
Thank you!!
Originally Posted by wyldckat View Post
Quick answer: If the template implementation defined for "Type" is "vector", the yes, it should be the vector "(1 1 1)".
Old   December 15, 2016, 09:23
Emad Tandis
EmadTandis is on a distinguished road
Hi openfoammaofnepo
can you explain about below code:
class outerProduct
public:
>::type type;
EmadTandis is online now   Reply With Quote
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 06:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 10:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 20:12
1D thermal stress problem simple barrodbeam newsboost OpenFOAM Running, Solving & CFD 3 January 2, 2009 15:12
A Simple Question Thomas P. Abraham Main CFD Forum 3 September 6, 1999 18:19
