May 19, 2011, 05:59 |
chtMultiRegionSimpleFoam with heat source
Samuel ARNAUD
Rep Power: 15 |
Hi Foamers,
I was trying to modify the chtMultiRegionSimpleFoam solver by adding a heat source (typically, here, to simulate a nuclear reaction in the fluid). I, therefore created a "heatedChtMultiRegionSimpleFoam" solver. Nevertheless, I'm facing a problem: If the heat source does exist (and can be represented in Paraview), it doesn't produce any energy and heat the fluid... I assume there's something wrong with the solver. May someone be able to find what's wrong in it! Best regards, PS: attached is the solver with the modified values. The new boundary is "Qheat". If something else is required, tell me
Sam |
May 26, 2011, 10:44 |
another thread with a similar subject
Samuel ARNAUD
Rep Power: 15 |
Sam Last edited by sixwp; May 27, 2011 at 05:02. |
Low temperatures modelling heat pump with source terms | stahl | FLUENT | 0 | November 26, 2010 16:43 |
[Help]How to set a heat source with period heating | fluboy | Fluent UDF and Scheme Programming | 0 | December 11, 2009 09:14 |
oscillatory heat source | Mehdi | FLUENT | 2 | April 7, 2008 17:12 |
solid heat source | ocy | FLUENT | 3 | February 22, 2005 22:58 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
